Stored Paint Life - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2005, 06:30 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Stored Paint Life
I have a lot of left over paints in pints and quarts that I have used in
the past. These are Base Coat colors by Sherwin Williams and DuPont.
I opened one the other day and it was starting to "gel" or at least
thicken. Is there something I can add to increase shelf life?
Is the stabilizer/reducer recommended for their reduction ok to thin with
for storing or is there something better for long term storage?
Old 05-02-2005, 11:48 AM
BarryK's Avatar
If the top is sealed good and paint is not exposed to freezing you should find they will be good for years.
The S&W, you want to make sure that no basemaker goes back into the can as that could cause a gelling problem.
The PPG, if activated you do not want to pour any back in can.
Another thing that will extend the life of the stored paint is not to pour any reduced leftover paint back to avoid pigment kick-out.
If it starts gelling do not try to thin and use.
Old 05-02-2005, 01:37 PM
jcclark's Avatar
The Penny Pincher
I have never poured any mixed paint back into the original can,
I figured that's a no-no but had to ask.
But aren't there some common ingrediants
in the base paint that could be added and extend it's life?
Old 05-02-2005, 01:48 PM
BarryK's Avatar
Well, kinda sorta!
But if done you risk causing a resin or pigment kick-out witch could render the paint useless sooner than left alone.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 02:32 AM
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 01:33 PM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 11:39 AM
Need color/top ideas.... Cracker Red Body - Exterior 4 09-07-2004 09:14 PM
Paint Shelf Life? Grey80Ghost Body - Exterior 2 08-10-2003 10:16 AM
