I can't can't help much with your question, sorry. But where are you getting the smoking deals from? I'm looking at possibly getting one of those engines as well. And if the price is right I'll get one now. Thanks |
Storing Engine
It probably wouldnt hurt anything to store one of these motors,although any breakin lube would likely run off the camshaft/lifters,so cam lobe wear might be an issue,although it wouldnt be too hard to pull the cam and re-lube it.If I was storing a motor I would pour some 2 stroke oil down the intake and put some in the spark plug holes also.Pre lubing would be a very good idea when you are ready to start it up.Turning the motor over a little bit every now & then would also be a good idea.
I actually completed my motor a year prior to installing it in my Cobra. What I did was build a engine stand and ran the engine according to break-in. After that I would run it once maybe twice a month just to keep things moving. I could tinker with it and do oil changes easily. I also run Evans waterless coolant and had no problems with corrosion. Just an idea.
Good luck, Everett. |
For NON running storage= Internal cylinder oiling, and duct tape all free-air entrances to the crankcase and intake to prevent constant exchange of humid air. Storage in climate controlled room is most important. Monthly manual turnover to change the ring and spring positions. Future cam break-in might be of concern. Future running will indicate valve spring softening and lifter collapse. |
And jegs has the 290 HP for 1625.99 in the latest catolog I have recieved from them. Remember alot of companies price match. |
I checked around and here's probably the best deal out there: http://paceperformance.com/index.asp...&ProdID=154046I believe I'm going with this shortblock. http://paceperformance.com/index.asp...&ProdID=183227 I already have a set of vortec heads and Intake. I got them from Teddisnoke over at stevesnovasite. I called Jegs about the price match but you have to figure in what they are charging for shipping. Last edited by NWayne; 03-06-2007 at 06:15 PM. |
http://www.jegs.com/webapp/wcs/store...48221_-1_10785
Ductape may be cheaper, but that kit seems like a good solution to what your looking to do. You may even want to run a little sealer or a thicker moly lube around the ports to seal it up better. |
It just adds a hundred dollar core charge when you add it to your shopping cart. The SDPC engine has a shipping charge of $255, which brings the total to $1694.
I have a SBC short block currently in storage, all I did was sprayed it down with WD-40 in all areas with a good soaking while I spun the crank, there is breakin lube on the bearings, then I bagged her on the stand.
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Engine | G-mac | Engine | 7 | 03-28-2006 10:21 AM |
| Storing bare engine block | chadzeilenga | Engine | 10 | 12-07-2004 11:32 AM |
| Storing an engine out side? | Dans83Olds | Engine | 9 | 11-01-2003 07:50 PM |
