Storing an engine out side? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2003, 02:33 AM
Dans83Olds's Avatar
Sucking Gas & Haulin' A$$
I was wondering if it would be alright to store my 355 outside for the winter? My beretta droped a valve, and I now have to use the garage to get that back on the road. With the car, and other stuff in there. There will be no room to have my engine in there.
Old 10-24-2003, 04:52 AM
302 Z28's Avatar
It can be stored outside if you take the proper precautions. I would first make sure all coolant is gone from the block to prevent cracking of the block due to freezing. I would then get a quart of Marvel Air Tool oil and squirt a good amount into each spark plug hole and rotate the engine by hand. If it has a carb on it make sure the carb is dry. Marvel Air Tool oil is better than regular Marvel Mystery oil in that it has rust inhibitors for use on air tools. Cover or wrap the engine in polyethelene sheeting.
Vince
Old 10-24-2003, 05:39 AM
Frisco's Avatar
Glad To Be Here
Originally posted by 302/Z28
Cover or wrap the engine in polyethylene sheeting.
Vince
This part of the post is NOT a good idea. On a sunny day, condensation will occur under the plastic and oxidation (rust) will form very quickly. Been there, done that!
The rest of the post is very good advise.
Old 10-24-2003, 08:03 AM
You mean storing an engine outside with no shelter? Not under the hood of a car? Bad Bad Bad idea. Engines sitting outside turn into junk don't do it. Find a place to stash the engine in your garage, stuff it in a corner, take it apart and put in your closet anything but outside.
Old 10-24-2003, 08:56 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
I've got my hopped up 350 just sitting in my Vega body and it has been sitting outside for over two years.
I fogged it before I pulled it and taped all the ports/orifices up. I take a ratchet and turn it over every now and then and she turns easily. I turn it over mainly to reposition the cam and relieve some of the tension on the valve springs, no problem so far anyway.
Old 10-24-2003, 09:39 AM
The most important thing is keeping in off of the ground. Lay a sheet of plastic on the ground, put a pallet on top of that, then your well lubed and taped engine on top of that, then cover it with something that breathes, like old carpet. Then you can put one of those blue poly tarps over that, but loosely. The poly tarps do breath, but you still want plenty of air to be able to get underneath it, so kinda prop it up and tie it down like a tent.
Old 10-24-2003, 10:46 AM
4 Jaw Chuck's Avatar
Fill the engine with oil, plug all the valve cover outlets and then invert it and shove it in an old dog house uncovered, as long as it doesn't get wet it will keep. Might want to pull the plugs and crank it over a few times to get all the oil out after.
Outlawed tunes from outlawed pipes
Old 10-29-2003, 06:14 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
build an "engine house" (think oversize dog house) out of some plywood and 2x4s.
Lay plastic sheeting down, then put the engine on a pallet on top of the sheeting.
Then build a cheep "shed" around it how some people do with their central A/Cs for their houses.
It's more solid than plastic, doesn't get mildewy like carpet, and keeps the elements out better than both.
-matt
Old 10-30-2003, 03:00 AM
I've had a freshly bored 350 short block in my 2-sided carport for almost 5 years. It was assembled with white grease on the bearings, and 30w Havoline everywhere else. It has been on an engine stand with a big contractor-size trash bag tied around it, with a few layers of corrugated cardboard hanging over it to keep cat claws out. I turn it over by hand & re-oil the cylinders & machined surfaces every 6 months or so. No new rust anywhere, and it always turns easily, even in the Louisiana humidity. In S. Dakota, I don't think you'll have a problem as long as it doesn't get rained on. The doghouse sounds like an excellent idea. I know a guy whose grand-dad sinks them in a tank of diesel fuel & covers the tank with a piece of steel.
Old 11-01-2003, 07:50 PM
I store engines outside but cover them with rubber sheets and be sure to plug the intake and exhaust to prevent condensation to enter the motor. Turning it over every few months is a good idea too.
