STP Oil Treatment (Contains ZDDP?) - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2012, 09:45 PM
I bought two 15oz bottles of STP oil treatment to put in my truck. It says something on the bottle about containing zddp.
Does it contain enough zddp to protect a new cam? I am planning to change cams in my truck and I dont want to wipe it out.
After performing the camshaft break-in with the break in additives, can i change the oil and add a bottle or two of STP oil treatment? Will that be sufficient to protect my new cam? And does it need to be done every oil change?
Old 02-12-2012, 10:14 PM
Last journal entry: update
At my local Wal-Mart, STP has some oil additive in a blue bottle. Reading the back, you don't see "ZDDP", but it does say "zinc dialkyl dithio phosphates", which is the long form. If that's there, it's fine for use after cam/lifter break-in, but during break-in you need something better.
Old 02-12-2012, 11:03 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Info from another board- http://forums.vintage-mustang.com/ge...treatment.html
Old 02-12-2012, 11:27 PM
327NUT's Avatar
This is for the op and really everyone since the myths and continual confusion about the zinc/phos. content in ALL oils is always questioned. In regards to the STP Oil Treatment...on "Bob's the oil Guy" forum one of the long time members says it has "1900 ppm zinc" ....which is a load IF it really has that content. Other members said they had sent questions to STP and got back an answer basically saying...that the level is proprietary but it has enough....well that's not good enough for me, if you can't tell me what's in it then I don't use it.
On a Cadillac forum one of the members asked the age old question...what kind of oil do you guys use? The reply's were the usual.... Valvoline VR-1...20w50, 10w30, Brad Penn...etc. Then one member said he uses Shell Rotella T 15w40 to which another member who obviously has never done any kind of research said ....not me since they took ALL of the zddp out of it.
I don't post much on any forum specially that one but I had to reply by using some figures I found by simply doing a little web searching...old Rotella T 15w40, zinc = 1276 ppm, phos = 1135 ppm ....new Rotella T 15w40, zinc = 1133 ppm, phos = 944 ppm. Really not that much difference and still plenty for everyday use....but not alone for a cam break in procedure and here's why.... a 4 oz. can of "ZDDP+" will make your new cam and lifters happy and gives you peace of mind. ZDDP+ zinc = 59,190 ppm .... phos = 53,980 ppm !! USE IT.
Since you already bought the STP you could probably use it after you change out the break in oil but I would just take it back....just me. You can do a forum search function for "cam breakin" and find a ton of info, READ IT and good luck on your new installation. Remember, everyone has their own thoughts on oil, oil additives, break in procedure etc.... and will argue the point till doomsday.
Old 02-12-2012, 11:39 PM
Thanks for that info cobalt. It looks like it might be ok to use STP Oil Treatment to protect my new cam after break in.
Old 02-12-2012, 11:52 PM
Sorry 327nut didnt see your post until just now.
I know its probably best to find a zddp additive, but i cant find any locally, and having to order it, wait on its arrival, and then change my oil, is a hassle.
It sure would be nice if the STP would have enough in it to make my cam happy.
Old 02-13-2012, 06:47 AM
Greg T's Avatar
www.krusinklassics.net
I wouldn't use that gooey sticky crap in anything. What,s worse? Changing your oil or changing a cam and lifters? Just use Valvoline VR-1 and be done with it.
Old 02-13-2012, 06:58 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Do be aware that some STP oil supplements are very thick and will raise the viscosity of the oil you add it to. Other STP supplements are not nearly so thick.
If you have to make do using the thick type STP (instead of motor oil that already contains enough additives, or a supplement like ZDDPlus, etc.), then I'd recommend using one step lower viscosity oil, i.e. 10w-30 instead of 10w-40, especially in winter/cold climates. Summer or hot climes will not be so badly effected when it comes time to start your cold engine.
Old 02-13-2012, 12:03 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
The STP blue bottle for 8 cylinders contains less zddp then the STP red bottle for 4 cylinders. It only takes one bottle of the red for an 8 cyl. engine and about 1 1/2 of the blue bottles for 5 qt systems and you have good protection.
GM dealers sell a very good zddp product for older vehicles. And use it in their oil changes on older vehicles.
Jester
Old 02-14-2012, 12:00 PM
http://www.hotrodders.com/forum/atta...id=62951&stc=1
If this certification tag is on any oil you buy with the teeth like a saw blade! That oil has no zinc in it! and is correct for cats. if the tag has no teeth and is just a round circle it has zinc!
Jester
Old 02-15-2012, 06:04 AM
topwrench's Avatar
Last journal entry: fish carb
I use VR1 or Joe Gibbs n add GM engine oil supplement or Jegs oil supplement.
Have no trouble with flat cams,never have!
I use either STP mucous thick stuff or Lucas to assemble main n rod bearings on big diesels only.
Ive been wondering for a long time about what kind of cam metallurgy or treatment M.A.N. engines use,they use a flat mushroom lifter and recommend synthetic oil,have 0 cam problems,Im gonna call today n find out.
I know at one time Nitriding was supposed to solve these problems with lobes flattening out,I dont know if this process is still used!
Old 02-15-2012, 08:24 AM
boatbob2
Stp?????????
HI,i have PROBABLY built more engines than MOST guys on this site,mostly SBC and Small Fords (289,302,and 351) i have NEVER used ANYTHING on those engines EXCEPT STP.MOST times,those engines sit around for awhile before being installed,have NEVER had a problem with any of them,due to using STP...I SWEAR BY STP you can swear at STP all you want,but,im too old to change now,(i wouldnt anyhow). i do pre oil those engines before starting ...
Old 02-15-2012, 08:48 AM
Banned
I've never used the STP, but I'll keep it in mind. I do use Restore and MMO often though and people call it snake oil, but the snake oil works, and it shows in compression tests and fuel mileage (both in the lab and in my garage). For assembly lube I use Isky rev lube or lubriplate on everything but valve guides (just 60w oil there). thuroughly priming the oil system is VERY important though on both new engines and engines that have sat a while.
Old 02-15-2012, 01:28 PM
You guys saying typical new oil has no ZDDP may have to look again.Check out the various oil brand websites and poking around you'll find what's in their oil.ZDDP is still there,but reduced to around 800 ppm depending on brand and grade.Not enough for a flat tappet hi performance cam of course......
Old 02-15-2012, 03:59 PM
327NUT's Avatar
Please read post #4
Zddp glen242 Engine 12 11-03-2011 12:59 AM
zddp additive 1932bantam Engine 11 05-18-2010 06:22 AM
ZDDP Additive Greg T Engine 1 06-06-2008 10:44 AM
ZDDP Oil capta1n Engine 5 01-03-2008 09:08 AM
