Straight / Angle plugs what is the difference ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2003, 12:48 PM
hi guys
what is the difference between Straight plugs setup & Angle plugs setup ???
I've read that angle plugs will provide more headers clearance
is there any difference in performance ???
thanks in advance
Old 11-30-2003, 01:17 PM
lluciano77's Avatar
Angle plugs set the spark plug closer to the exhaust valve in the head. You get more efficient ignition there. Most aftermarket companies now have the straight plugs in the corrected location. It all depends on the type of head wether angle or straight plugs will make a difference.
Old 11-30-2003, 01:46 PM
Rice1965's Avatar
As a rule angle plugs will not grant clearance for your headers. In addition you tend to only see performance increases when using domed pistons, not with flat tops.
Old 11-30-2003, 01:52 PM
lluciano77's Avatar
You can buy headers that clear with either angle or straight plug heads. I have never heard any difference between dome or flattops.
Old 11-30-2003, 02:37 PM
Auto-Part's Avatar
Most GM BB have angle plug heads and the will Just clear headman headers. I said just
Old 11-30-2003, 02:47 PM
Rice1965's Avatar
lluciano77 said this better than I did. Better for me to say you need to check with the seller before you purchase headers to be sure they will clear angle plugs.
Old 12-01-2003, 10:25 PM
guys ..thanks for your great help
Old 12-01-2003, 11:00 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Yep it takes special headers for angle plug heads.
Headman built my stainless ones ,and then sent me a set of flanges to get enough room for short plugs on my 69 355 camaro.
All Big Blocks have angle plugs.
Troy
