Straight Axle 1956 Mercury Monteray Gasser - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2011, 08:57 AM
Benton007's Avatar
Last journal entry: Blown 350 on the test stand
Good morning
I need you advice setting up the lenght of a straight axle for my new project. Its a 1956 Merc Monteray Gasser 429 ford C6 and a ten bolt rear. I got the papers sorted out, the first time I drove it with 2" straight home made pipes I set off every car alarm on my block. It came with an old chevy truck drop axle 53 1/2 king pin to king pin , drum brakes and six lugs. The axle is no good bent, So I need to replace it with a speedway kit but what would be the correct one to choose.
This is what im working with 71" inside of fender to fender, 34" outside to outside of frame and the leaf springs are the same. Springs are 2" wide and 32" center hole to hole. Speedway has great info and a pdf file but I just thought I would ask you because right is right and I want it to be safe for me and my two boys. The front tires have to be strong enought to handle the extra weight of the merc and the 429 ford so thats it any info websites for advice is would be great, ill try to add some pics if . thanks for you help Laters Ben Nate and Nicky
Old 10-01-2011, 10:44 AM
F-100 Ford pickups had a straight axle up until 1965 or so. They would be strong enough for your application. They have 5 lug wheels with the 1/2 20 NC threads on the lugs. STRONG. I believe the track width is 60 inches ( wheel mounting flange to wheel mounting flange ). They have excellent brakes ( for drums ) and disc brake kits are available.
I do believe I would investigate the F-100 axle ... because I consider it a LOT stronger than the kit from Speedway.
DEUCE ... Moderator
Old 10-01-2011, 11:00 AM
Benton007's Avatar
Thanks Deuce that is very helpful Im trying to load some pics but no luck yet. My sons and I want to make it more of a street rod to hit the local shows.
Old 10-01-2011, 01:06 PM
willowbilly3's Avatar
Last journal entry: Body mods
I'd find an econoline axle.
Old 10-03-2011, 08:14 PM
I'm using a 50 F1 axle under my 55 Pontiac. I like the looks of the factory axle, plus the strength of the forged axle . It's a little narrower than the econoline axle by a few inches.
Check out droppedaxles.com for pics and specs for the early axles..
1956 mercury steering column wiring Andy Gross Suspension - Brakes - Steering 0 09-09-2011 01:56 PM
1956 mercury steering column wiring Andy Gross Electrical 3 09-08-2011 08:56 AM
What are the advantages of a gasser straight front axle? fiscus Suspension - Brakes - Steering 10 11-10-2009 03:54 AM
Starter for 1956 Ford Mercury Monterey LHD EBodiat Electrical 1 12-13-2005 06:25 AM
A different gasser-style straight-axle question: gowjobs Suspension - Brakes - Steering 3 08-15-2004 08:29 AM
