Straight Axle mix - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2010, 11:00 AM
Straight Axle mix
Does anyone know if you can take the front hubs and brake assembly off of a 1967 chevy c10 (5 lug (if it matters ( parenthesis inside parenthesis )))
and put it on the spindle of a 50s chevy truck straight axle.
I want to run a straight axle in my International pickup and use my new wheels. They are 5x5 bolt pattern to match my 12 bolt rear end. I want to stick with drums brakes and dont want to buy a kit.
thanks for any advice.
First post!
Old 01-25-2010, 02:16 PM
In a word notonyourlifeforgetaboutit.
Nope, not even close. First off, a 49-54 Chevy passenger car spindle will bolt on, that will give you the standard 5 on 4-3/4" GM passenger car pattern.
You can also get hubs from many sources for this, I believe Summit has them.
Old 01-25-2010, 02:32 PM
As I recall, 49 to 55 Pontiac, and Olds, hubs, drums, and backing plates fit a Chevy truck front axle.
Old 01-25-2010, 08:19 PM
Well that wasnt what i wanted to hear.
time for plan B...
did the 50s truck straight axles come with 5x5 pattern? (i would have preferred the newer setup though)
or maybe plan C...
Have any of you guys heard of redrilling the hub and drum for a different pattern?
Old 01-25-2010, 08:29 PM
ericnova72's Avatar
More for Less Racer
Yep, no problem for anyone with a little machinist ability and a Bridgeport milling machine. Moser (the gear and axle people) will also do it.
Old 01-25-2010, 08:37 PM
so... i could get a straight axle out of a 50s pickup, give it a brake job, have the hubs and drums redrilled, and id be good to go... right?
Or wait, maybe it would be a better idea to just do the same thing to a 60s (or 70s if possible) ford van or truck. The parts would be newer and would probley have cheaper parts.
the possibilities!
What do you think of a 63 straight axle Falcon? 63' Falcon Gasser Suspension - Brakes - Steering 23 12-19-2013 10:16 PM
straight axle jstaley4 Suspension - Brakes - Steering 1 03-19-2007 07:44 PM
Straight Axle and Rack & Pinion Murff Suspension - Brakes - Steering 12 06-15-2004 03:21 AM
Straight Axle for 63 Chevy2 musky2 Suspension - Brakes - Steering 15 01-04-2004 01:15 AM
