Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - straight axles options for ford pick up street rod
Old 12-22-2009, 08:44 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Originally Posted by 77bronco_ed
... I like the bagged 32 pickup set up... Have any build pics of that one?
Unfortunately not. These are the only other construction pics I have of the '32 that are even close to showing the front suspension. But the logistics of the Twin I-Beam are all pretty much the same. So the builds in the other two journals I linked above should give you a pretty good idea of what you would be dealing with.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
