Straight Front Axle With Rack And Pinion Steering ... Is It A Good Idea ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2012, 05:19 PM
Is It Ever A Good Idea To Steer A Straight Front Axle With A Rack And Pinion Type Steering ???
Old 05-13-2012, 08:15 PM
It could work but isn't ideal. Are you planning manual or power? You weren't planning to mount the R&P to the axle were you? That would be a bad idea.
Old 05-13-2012, 09:46 PM
Manual Rack Is Fine ... Power Is Okay ... My Heart Is Not Set On Either ...
I Have Seen Racks Mounted To The Axle ... But I Do Not Like The Idea Of A Steering Shaft Telescoping Into And Out Of It's Self Constantly !!!
I Am Envisioning That This Will Be A Leaf Spring Car ... Without Very Much Spring Travel ...
I Mostly Wanna Be Safe .... No Road Race Slalom Courses ...
Just Go Straight ... And Slow Down ...
Thanks For The Reply ... Rex
Old 05-14-2012, 07:04 AM
Wiki Edits: 27
Unisteer ?
check out a unisteer, I saw a Rack mounted in a t bucket years ago with the old style upright column and only one side of the rack used going foreward to the left spindle.
Old 05-14-2012, 08:00 AM
So why not just use a steering box that you know works, why the desire for a rack?
Old 05-14-2012, 09:01 AM
I Hate The Rear Steer ... I Would Like To Get All Of My Steering Components In Front Of The Axle ... I Am So Tired Of The Shock Towers And The Steering Gear Box Being Jammed Up In The Way Of Everything ...
I Would Be Happy With A Front Steering Box And A Cross Steering Set Up ...
I Had Envisioned The Tierods Running Between The Leaf Springs And The Frame ... But ... Who Knows ...
I Will Post Pics When The Tear Down Begins ... And We Can Take It From There .... Thanks For The Reply
Old 05-14-2012, 09:22 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Well then If I remember right Ford Rangers "small truck" are front steer so one of those steering boxes would work..About 50 bucks or so at the pi-a-part...
Sam
37 Dodge Rack & Pinion on Straight Axle New Bird Suspension - Brakes - Steering 2 02-12-2011 05:27 PM
Rack and Pinion with a straight axle Chris Kemp Suspension - Brakes - Steering 7 01-10-2009 08:15 AM
split straight front axle with rack and pinion dmcurry22 Suspension - Brakes - Steering 15 01-08-2009 11:15 PM
Rack&Pinion on old type straight axle austin Suspension - Brakes - Steering 53 01-29-2007 08:18 AM
Straight Axle and Rack & Pinion Murff Suspension - Brakes - Steering 12 06-15-2004 03:21 AM
