straight pipe for me??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-30-2003, 02:41 PM
ztoy's Avatar
speed freak
Post
hey slider, hows that exhaust turning out?
  #17 (permalink)
Old 04-30-2003, 05:05 PM
slider in wa's Avatar
Slider in Wa.
Post
Not yet, but it is on the list. Gotta flip the rear end, put 3" drop spindles in the front. Loose the "SERVIS" bed on it, install a 40 gal gas tank between the frame rails, and loose the saddle tanks. Considering a "Gear vendors" overdrive unit. Right now i`m trying to learn a little bit about body work. I really want to do everything i can on this one myself.
Hea , thanks for asking.
Slider in Wa.
  #18 (permalink)
Old 04-30-2003, 05:36 PM
drgnwgn289's Avatar
Post
Why don't you get whatever mufflers you want and then run dump tubes? Thats what I do...its fun to switch it up every once in a while.
  #19 (permalink)
Old 04-30-2003, 06:05 PM
6567GTO's Avatar
Tire Fryer
Post
1BAD80 posted a link to an article written by the Hands who are excellent Pontiac people. I just wanted to add that they also put out a CD of exhaust sounds which consists of something like 54 soundtracks of different exhausts and mufflers both with an X-Pipe and without attached to a 455 Pontiac engine revving at different RPM's. The CD used to also come with a spread sheet showing decibal levels and flow numbers. If anyone is interested in buying the CD, here's a link.
<a href="http://shop.sslonline.com/cgi-sz4/webc/sz41/accounts/a0004287/st_prod.html?p_prodid=199&p_catid=1&sid=8jw30t0lg2 Ui8Of-41103271249.96" target="_blank">Silent Power CD</a>
[ May 01, 2003: Message edited by: 6567GTO ]</p>
  #20 (permalink)
Old 05-01-2003, 04:45 PM
Adrenaline_Fiend's Avatar
Chevy sittin' low
Post
One of those articles said that a 250-300 horse engine should have like 3in. exhaust....So, what IS the deal with back pressure. I've heard alot that 2.5in. would be plenty for the 400+hp 355 that i plan on building....what's the deal?
  #21 (permalink)
Old 05-02-2003, 06:19 AM
6567GTO's Avatar
Tire Fryer
Post
Adrenaline - are you talking about the link 1bad80 supplied because I couldn't find that written anywhere. That doesn't sound right at all.
2.5" IS plenty for what you're building. You might want to add a crossover pipe. (X or H)
You cam also run 3" primaries up to the mufflers and then run 2.5" tail pipes without any restriction.
  #22 (permalink)
Old 05-02-2003, 05:29 PM
ztoy's Avatar
speed freak
Post
man, I read an attachment from someone here about exhaust and some very good info is there but am not sure how to do this, so I will try anyway....
www.boylesworks.com/ta400/psp/exhaust.html
this is quite enlightening
  #23 (permalink)
Old 05-02-2003, 05:32 PM
ztoy's Avatar
speed freak
Post
jeez, see, it won't work! anyway that is the web address.......
good luck slider, sounds like you have your work cut out for you doing body work <img src="graemlins/crash.gif" border="0" alt="[crash]" />
  #24 (permalink)
Old 05-02-2003, 09:39 PM
bluesman123's Avatar
Post
Is it possible to put an X or H crossover in a dual cat system? Doesn't that confuse the HO2 sensors as there's one for each bank??
  #25 (permalink)
Old 05-03-2003, 01:56 PM
6567GTO's Avatar
Tire Fryer
Post
Bluesman, yes it's possible to use an X pipe with dual cats. Here's a pic of one from DrGas which is where I bought my X-pipe. The sensors are on the front pipe before the X so they aren't affected.
<a href="http://www.drgas.com/photos.html" target="_blank">X-pipe with dual cats - click here</a>
Go to misc. pictures and click on #6.
[ May 03, 2003: Message edited by: 6567GTO ]</p>
  #26 (permalink)
Old 05-08-2003, 06:07 PM
Post
Nice link, 6567! What difference did your X-pipe make in the sound?
  #27 (permalink)
Old 05-08-2003, 07:50 PM
Post
here is a site with exaust sounds check it out
www.exhaustsoundclips.com
  #28 (permalink)
Old 05-09-2003, 04:20 AM
6567GTO's Avatar
Tire Fryer
Post
Bluesman - I actually installed the system on the car at the same time as the motor so I can't compare it. But, it sounds great at idle (nice and aggressive) and quiets down a little throughout the midrange (no resonance in the interior) and has a kind of a raspy Indy car sound at the tail pipes at high revs. Kinda hard to explain, but I like it.
  #29 (permalink)
Old 05-14-2003, 03:03 PM
ztoy's Avatar
speed freak
Post
6567GTO, how do you like the performance of those x pipes?
  #30 (permalink)
Old 05-14-2003, 04:52 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Adrenaline_Fiend is refering to the site from Steve 5.0 Towncar (good site Steve)http://www.nsxprime.com/FAQ/Miscella...austtheory.htm
[ May 14, 2003: Message edited by: 1BAD80 ]</p>
Luv the smell of NITRO in the morning.
