Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Straight Pipe Myths
Old 12-06-2004, 04:52 PM
packratwrecker's Avatar
packratwrecker packratwrecker is offline
Too many hobbies!
If you decide to run straights, keep in kind that the bigger pipe you use, the more mellow the tone will me.
2" sounds nasty on a small block chev, a 6.2 diesel, a v-6 Explorer, or a 230 straight 6, with split manifolds.
If you are going to do flamethrowers with mufflers, I'd use glasspacks, or steelpacks. If you try it with trash cans, and make a mistake, you'll end up with mufflers that look like pregnant puppies.
I ran straights on my 49 Chev, out 4" stacks, until I couldn't stand it anymore.
I took the stacks off at the elbows, and welded in blocker plates, with glasspacks on them. Most people don't even know I have mufflers, until I tell them.
The 4" stacks above the glasspacks gives a pretty effective expasion chamber, so you get nice orange rolling fire, instead of blue jets.
FYI I am a redneck. I built my own flamethrower setup, so that it would be safe, and easy to use.
