Straight Six Ford Misses When Wet?! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2012, 11:10 AM
Took my straight six ford f100 out yesterday in the mud a little and some water and it ran fine in the more stickier mud but when i got in the mud with more water it started to miss and had no power whats so ever. it would eventually come out of it but when i hit water again it would miss again. i checked most of the wires going to the distributer and put petroleum jelly on almost all the connections for the coil and spark plug wires but it still would do it.
Old 03-02-2012, 11:25 AM
Wiki Edits: 31
get another distributor cap
Old 03-02-2012, 12:38 PM
when i opened up the cap it looked dry.
Old 03-02-2012, 02:32 PM
Wiki Edits: 31
And I had a distributor cap that looked great, fire all the wrong plugs and the engine would pop like it was 180 out... looks can be deceving. it's got a crack or is carbon tracking. it doesent take much to make them jump and miss.. plug wires will also do it if there at all bad
Old 03-02-2012, 04:12 PM
I'd put a set of wires on it also.
Old 03-02-2012, 04:51 PM
thanks guys.
Old 03-02-2012, 05:39 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 with Matt on this you have some moisture getting in somewhere and is usually is the dist cap. JMO
Cole
1984 Ford 302 jerks, stumbles, misses under load breemijoe Engine 2 01-19-2011 08:31 PM
Ford 4.9L 300ci Straight-Six wcchoppr Engine 5 01-29-2010 11:07 AM
86 ford straight 6 fordsinfl Engine 1 08-09-2009 05:40 PM
ford 46 straight 6 bosse Engine 4 09-16-2003 11:57 AM
Ford Straight 6 swap to a 302 or 351 BillyBob1950 Engine 5 01-18-2003 02:42 PM
