straight or tilt column - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2005, 06:30 PM
I'm building a 1932 3 window and I am having trouble deciding what type of column to get. My dad says do a tilt but I'm leaning toward the straight, it fits the hot rod type theme. I just wanted some suggestions from others. thanks
Old 01-14-2005, 09:05 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
tilt vs straight
I took the tilt wheel out of my car and replaced it with a straight. I have had the bolts in the tilting mechanism come lose on more than one column. I just don't like them. A friend had her tilt lock let go and had the wheel flopping around. If your one for taking them apart. The straight column is easier to work on.
Old 01-14-2005, 09:16 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
If your seating situation is tight, you are very big or very small, tilt can be nice..... but it probably isn't necessary.
Old 01-15-2005, 07:29 PM
302 Z28's Avatar
Go with the tilt, it isn't hat much for the added convenience it gives, especially on long road trips. If there was that much problem with tilt's coming apart they would have been recalled. I have never seen one come apart or loose, unless it has been worked on by an incompetent mechanic.
Vince
Old 01-16-2005, 01:27 PM
FASTFORD's Avatar
i installed the tilt column 6 years ago in my coupe, i`m glad i did.
i took alot of time to insure it was located correctly, even thought i didn't need the tilt. on the 1st long trip in the car, i found that tilted down into the 2nd notch was MORE comfortable to my hands & arms.
if you use the straight column, get some measurements from your daily driver to assist in locating your new set-up.
example: floor to seat height, floor to bottom of steering wheel (same size wheel for accuracy) . angle of column will help also.
hope this helps, G`luck.
