Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - straighteight upgrade
Old 10-02-2012, 10:26 PM
timothale timothale is offline
Wiki Edits: 27
carter wcd carbs
G m used carter WCD 2 barrels on those dual setups/. They were a pretty good carb and had metering rods that you could adjust the lifter cam on the linkage , The WCD's we used by american motors up thru the 70's, In the 60's you could still buy the weld on flange kits to add more carbs to your stock manifold. I made my own a few years ago and made a spider leg intake manifold for my corvair (6 cyl flat engine ) powered dunebuggy and ran a single holly 500 2 Barrel carb.
