Strange 200 R4 troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2003, 08:46 PM
Hey guys, i have an 87 monte carlo ss, mild 350 with a strongly built 200-R4. When i purchased the car the guy who sold it to me said the trans was all out build so i have no history on what was really installed in the trans. When i first got it, the trans chirped second and hit third and OD really strong. The shift points seemed right, but soon i found out the car had a thottle cable problem so after i changed the bracket i had to play with the TV cable for a few days. The trans shifts exactly like it used to, but one day out of the blue the trans stopped downshifting into first at a dead stop unless the cars been driven for at least 40 minutes. Now the car wont ever shift into first unless i manually put it in first or shift neutral at a stop and pop it back in drive, which engages the trans back in first. Also when in Od the car wont downshift now matter how much gas you give it and it wouldnt downshift from OD when i first got the car either. The trans still shifts strong and has perfect shift points, but these little problems really annoy me.
Also i dont know if the trans is lockup because the casing has no computer terminals on it and i havent felt it lock up before. The guy said it was the trans was the original 87' 200-r4 that was built and he swears he cant remember what was done to the trans. Any ideas on what was done or what is wrong with this mysterious trans?
Old 12-09-2003, 10:22 PM
200r4's use the cable linkage to control both line pressure and kick down unlike turbo 350 and 400s which use a vacuum modulator to regulate line pressure it is for this reason that one the 200r4s the cable adjustment is critical. If it is not adjusted right the transmission will slip underload as the clutch apply pressure is wrong. These transmissions can be wiped out very quickly with the improper cable adjustment.
Old 12-11-2003, 04:17 PM
He's right, from what I know, you probably have killed your tranny. You NEVER play with the TV cable.
Can't remember how to adjust it at the moment, but I think it was hold the throttle all the way down on the carb(NOT WITH THE PEDAL!!!) to WOT while you are holding the snaplock on the TV cable. Than release the snaplock and it is adjusted. I think thats how it works, but I do know that fiddling with the TV cable will KILL the 2004R, a major weakness.
Old 12-11-2003, 06:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool Re: Strange 200 R4 troubles
UNLIKE a 700r4 tranny, the 200-4r will NOT down shift to first gear if the TV cable is pulling TOO much at idle. The 200-4r TV cable must be set real close to correct minuimum setting for it to down shift to first at a complete stop. From your description is sounds like something to look into.
This is a quirk of the 200-4r
Now the lack of forced down shift from OD... you say this is the WAY the tranny acted when the vehicle was purchased. IF the valve body has the aftermarket TV sleeve in it for WOT upshift to OD... this sleeve usually does not provide for a forced downshift to OD . You must manually down shift the shifter to 3rd
