strange 60 vs moser 60 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2010, 03:58 PM
Jason7504's Avatar
i was gonna either get a moser 12 bolt with 33 spline axles, true trac posi, 1350 yoke, spring perches braced and TA alum girdle or a moser 35 spline dana 60 with true trac posi, spring perches braced. There both about $2700 shipped. I'm not much for the 9".
I found a brand new strange dana 60 locally for $2000. Has anybody had any issues with the strange dana 60's? Freddie said they use a different axle seal that can leak sometimes.
Old 12-21-2010, 06:06 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
have you looked at dutchman, they are really close to you.
i dont know if they are any cheaper, but they are local and you would be able to stand at their counter to order and no big shipping costs.
ive heard some good stuff about them from some guys at work.
http://www.dutchmanaxles.com/
Old 12-21-2010, 06:42 PM
Overdriv's Avatar
For what it's worth, I have Strange axles and bearings/seal in my 9" and have had zero problems.
I'm sure the Strange 60 would be a excellent piece.
Moser is great stuff also, but I'd save the $700 and go with the Strange 60 if it was exactly what I wanted.
Just my opinion.
If I may ask, what are you going to run this in? If you only need a 12bolt, a 60 is a bit overkill. The 60's weigh lot more than a 12 bolt or a 9". The 60s are VERY durable.
Jason7504's Avatar
i see parts on there website but do they make bolt in crate rear ends?
Old 12-21-2010, 06:46 PM
& matts38chev
i dont know, i just noticed you are in vancouver and i knew they are in portland, what 15 mins. away?
Old 12-21-2010, 07:06 PM
Jason7504's Avatar
the only problem that i see is that the only options for wheel studs are 1/2" and 5/8" but my wheels use a 7/16" lug nut
Old 12-21-2010, 07:14 PM
ericnova72's Avatar
More for Less Racer
Any wheel that takes a 7/16" lig nut should take a 1/2" also, either by changing the lug nut(if they have a mag shank type nut) or by drilling the wheel hole oversize(if they use a tapered acorn type nut).
What is the wheel??
I have also used Dutchman axles with not a problem.
Old 12-21-2010, 10:11 PM
SSedan64's Avatar
Yes, they have bolt in Rears, look in the Catalog.
9", HD-Dana 60 & Quick Change rears.
http://www.dutchmanaxles.com/images/...s/axle_cat.pdf
http://www.dutchmanaxles.com/products/orderfrms
Old 12-21-2010, 11:57 PM
Jason7504's Avatar
What is the wheel??
well the wheels are 15x10 cragar SS with unilug. they are the mag shank type nuts i believe.
Old 12-22-2010, 12:00 AM
Jason7504's Avatar
well it's going into my 580hp 81 camaro and yeah it's a little overkill but can't beat the price and it's bomb-proof. If i ever bump up the power, i won't have to worry about it. Its only about 25 more lbs than the 12 bolt but i heard that the more efficient gear in them almost make up for the weight difference.
Better to be overkill than too weak
Old 12-22-2010, 06:57 AM
Overdriv's Avatar
I agree, go for it. I was just wondering.
Old 12-22-2010, 11:45 AM
ericnova72's Avatar
More for Less Racer
All you need are 1/2" mag shank nuts, as the Cragar unilugs also fit Fords and Chryslers, and they both use 1/2" studs. It is basically the same nut, same OD on the shank to fit the hole in the wheel/washer but has a 1/16" larger hole drilled and tapped in it.
Old 12-22-2010, 11:58 AM
Jason7504's Avatar
ok well i called dutchman and there complete dana 60 is like $2400. not sure if they charge extra to set up the differential, forgot to ask. But the strange is cheaper.
I'm not sure what to do about my brakes though because i want to reuse my 10 bolt brakes if i can. Does anybody know if i will be able to reuse them on the strange dana 60?
Old 12-22-2010, 12:04 PM
& matts38chev
so your are saying the local strange axle you found is 400.oo cheaper
does it have no brakes?
and did the dutchman axle also have no brakes?
Old 12-22-2010, 12:06 PM
Jason7504's Avatar
well the local strange dana is $2200 so its $200 cheaper and fully assembled. they both didn't have brakes
STRANGE or MOSER for street sooper Transmission - Rearend 11 06-19-2010 12:20 PM
moser 12 bolt sheldonw Transmission - Rearend 0 05-20-2008 09:28 PM
Moser 9" rear for 3rd gen F body........... Trans Am Tony Transmission - Rearend 3 08-04-2007 08:38 PM
How much oil in a moser 9 inch? Stingray_Vette Transmission - Rearend 1 06-24-2004 07:00 PM
Greg Moser Killed Benji Hotrodders' Lounge 1 05-19-2003 07:13 PM
