Strange beeping/whining sounds from electric fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2013, 06:54 PM
dasyhard's Avatar
Lately I've been hearing beeping or whining sounds from my electric fuel pump after driving a few miles and since the motor and exhaust produces a lot of noise I can only hear these sounds only during stops. It sounds like a home fire alarm that is mounted on the ceiling. I'm almost positive it's the pump. Anybody had this experience and if so, is the pump going bad? Thanks in advance to anyone that can give me a remedy.
Old 09-08-2013, 07:06 PM
techinspector1's Avatar
Wiki Edits: 326
Check connections for allowing air into the pump.
Install filter before the pump to eliminate foreign materials being pulled into the pump.
The Following User Says Thank You to techinspector1 For This Useful Post:
dasyhard (09-14-2013)
Old 09-14-2013, 04:50 AM
dasyhard's Avatar
Thanks for the advice sir...but I did check the connections and they're all good and the Fram filter is located less than 3 feet from the pump. The pump is an Aeromotive brand and it is super loud and so annoying during idle. I'm going to replace it with a Holley HP 150 and hopefully I don't hear those beeps again. Thanks again.
Old 09-14-2013, 08:32 AM
Wiki Edits: 326
Mount rubber isolators to the car, then mount the pump to the isolators. Never bolt an electric fuel pump directly to a metal part of the car. I used to use those black rubber muffler hangers that had holes drilled in them. Got them at Pep Boys, but don't know if you can still find them there. Maybe at a muffler shop. Also, don't attach a hard line directly to the pump. Attach short pieces of non-metallic hose to the pump inlet and outlet, then attach the hard lines to the non-metallic hose. With the pump isolated from the car in this manner, she'll be as quiet as a church mouse.
Old 09-14-2013, 05:28 PM
dasyhard's Avatar
Thanks, I'll follow each of your steps to the T. I just purchased the rubber garage door seal which is thin and should wrap around the pump before securing it with the clamp.
Old 09-15-2013, 05:18 PM
Wiki Edits: 326
I found a link to the stuff I was talking about. Use the clamp around the pump, with or without your garage door insulation, but mount the pump/clamp to the car using rubber like this......
Walker Exhaust 36273 Exhaust Hanger Metal Swivel Rubber Strap Universal Each | eBay
No hard part of the pump or clamp should be in contact with any hard part of the car.
dasyhard (09-19-2013)
Old 09-19-2013, 07:15 AM
dasyhard's Avatar
Thanks, I also found it on amazon where I usually purchase parts due to free shipping on most parts I order.
Walker 36273 Hardware Hanger : Amazon.com : Automotive Walker 36273 Hardware Hanger : Amazon.com : Automotive
Can an external electric fuel pump suck fuel through an in the tank fuel pump? v123 Engine 3 06-02-2013 01:42 PM
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
strange whining noise from T-400 .. Fizz Transmission - Rearend 17 07-04-2004 11:58 AM
