hello again its been a long time, so here is something new. 1995 olds 98 series 2 engine vin k. each time I accelerate hard(passing a car on a two line road) the brake light comes on till I stop accelerating. could I have vacuum leak to the booster? I have no fluid at the booster from the master cylinder. brakes are firm on braking.I did recently change the intake manifold for preventive maintainance( hydrolock), could this be the problem?
thanks for the info. will check both. the car does a fluid sensor, and the mc is full. never thought about the engine torgue. would that also indicate bad engine mounts?
Yes obviously.
But engine torque may also result in damaged acc. wire.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
