I'm getting a strange vibration somewhere in the driveline of my 68 fairlane? Its got a 351W, 4-speed, and 3.50 posi rear. Vibration damper is tight, bellhousing is tight, driveshaft hasn't thrown it's balance, tires are balanced and have no knots. Vibration starts at about 3300 rpms and quits at 4000. Any ideas?
want to hear a even weirder one. on my bro in laws 86 mustang we developed a light drive train vibration. i tried balancing the tires over and over. checked the u joints, checked axles, driveshafts weights, bearings, tranny mounts ,tranny tailshaft bushing. you name it it was checked. so i just decided to balance the driveshaft out of desperation. as i took down the drive shaft some thing inside made a clunk.
i cut the shaft in half and found a rubber o ring with a small piece of pipe inside. the pipe fell out of the oring and was moving around inside the driveshaft causeing a imbalance. so i installed aluminum unit and no more vibration. anyone ever see a pipe in the driveshaft before. |
had a similar problem in a toyota P/U, replaced the clutch, pressure plate, throwout bearing, and pilot bearing, no more vibration, i believe it was the pilot bearing causing the problem.
(yeah, i know, toyotas aren't supposed to have problems,,,350,000 miles on the original clutch, NOT BAD,HUH?????????? |
you must not be one to see how well a toyota can smoke the tire... don't laugh my g/f 90 pontiace sunbird (more pathetic than the toyotas)can smoke the tires pretty good especially with the e brake on
Oh yeah by smoking the tires I mean a little sqeak and the thing doesn't blow up
If all the other replys don't work check your axles. I have had a similar problem that was caused by a slightly bent axle.
[quote]Originally posted by Necro:
<strong> anyone ever see a pipe in the driveshaft before.</strong><hr></blockquote> see it all the time, gm did it alot. supposed to work like a damper, bigger drive shafts some times use cardboard tubing inside. |
[quote]Originally posted by stonedchihuahua:
<strong>Oh yeah by smoking the tires I mean a little sqeak and the thing doesn't blow up</strong><hr></blockquote> i dont smoke the tires on the "yota", i save that for my '85 cutlass, 455 with a 400 tranny, shift kit, motor is stock except for the intake and the carb. i smoke the tires when i can afford the gas!!! |
