Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Strange GM Regulator/Alternator Problem
Old 11-27-2011, 11:08 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Terminal Identification:
F= Field (F terminal on alternator)
2=Stator (R terminal on alternator)
3= B+
4= Light
The regulator is grounded to the rad support. I suggest that you check the ground connections from the regulator to the rad support, rad support to frame, and frame to engine.
Use of those uninsulated braided straps is a good idea at any point that has a moveable joint (like a hood or trunk lid) ... or any part that may be rubber mounted (i.e. rad support, truck pickup box).
NAPA (Echlin) Part Numbers if you happen to need them:
VR142 Voltage Regulator
VRC142 Voltage Regulator Connector
VRA142 Alternator Connector
