strange inside panel coating - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2005, 07:58 AM
rlackey's Avatar
Rich Lackey
Last journal entry: Rich Lackey is back on Hotrodders!
I have this black hard coating on the inside of the quarter panels in the trunk and on the wheel wells, as well as inside the wheel wells. I don't know what it is or how to remove it. Does anyone know what it could be?
It's also in the footwells and coating the underside of the driveline tunnel as far as I can tell. I want to get rid of it but it's tough stuff. Sanding doesn't work, just gums up the sand paper.
Help!!
Rich
ID:	4899   Click image for larger version
Old 05-07-2005, 08:49 AM
rlackey's Avatar
Rich Lackey
And why aren't my pictures showing up???
Old 05-07-2005, 09:19 AM
New Member
I had that stuff on y truck when i was striping it. I just used a 2inch putty knife and scraped most of it off then striped it.
Almost forgot I see the pictures.
Old 05-07-2005, 10:56 AM
Last journal entry:
If you have a gas torch, you can try heating it up and seeing if it makes it easier to scrape the stuff off.
Old 05-07-2005, 11:02 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
It is undercoating.
It takes Heat, Scraping and tons of patience to remove it.
Later,
WEIMER
Old 05-07-2005, 11:07 AM
rlackey's Avatar
Rich Lackey
Grrrrrr
That's what I thought. What a pain in the *&#. As if this car wasn't taking long enough to strip.
Rich
Old 05-07-2005, 11:16 AM
A/G WILLYS's Avatar
that's tar, we just finished 3 cars and I found the best way to get it off is oven cleaner, the longer you let it sit and the heavier you put it on the better.
Old 01-05-2006, 04:44 PM
You can use an air chisel to vibrate it off. Careful not to use to much pressure while chiseling so as not to damage the panel. be extra careful if you are using it on the inside of a quarter panel or some other exterior panel. It works great for doing the under side and inside the wheel wells.
Old 01-05-2006, 06:31 PM
nissan's Avatar
Last journal entry: 1930 chevy ratrod pick-up
nissan
use bowman gasket and decal remover,(bowman barnes group),best stuff on the planet,also worked great on my wifes oven.didn't cost much because a little bit goes a long way.all there products are top of the line.they have every kind of clip an fastner for autos.
metalshaping and panel replacement '40 Willys roof Randy Ferguson Body - Exterior 18 11-26-2005 09:00 PM
Metalshaping/Body Panel Fabrication Randy Ferguson Body - Exterior 15 06-06-2005 11:01 PM
Repair of large dents in roof? rlackey Body - Exterior 9 01-28-2005 10:36 PM
Quarter Panel Patch Ron M Body - Exterior 1 07-27-2004 01:12 AM
protecting inside of new body panel crshrmn3 Body - Exterior 10 10-03-2003 09:36 PM
