STRANGE or MOSER for street - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2010, 06:43 PM
I may end up putting bigger tires on this brute to try and hook up. Is there a general preferance between the axle companies for street? Moser is about 2/3 the price of the others
Old 06-17-2010, 06:47 PM
prostreet6t9's Avatar
Differential/Driveline
You might look here http://www.dutchmanaxles.com/ and compare with the others. I've had great luck with Moser and the Dutchman stuff.
Old 06-17-2010, 09:40 PM
ericnova72's Avatar
More for Less Racer
Same here, I have used Moser and Dutchman, only thing I have ever used from Strange is Ring & pinion and c-clip eliminators. Don't know if Strange is good or bad for axles but they have been around a while, must be decent. Mark Williams is another I have not used either.
Moser is close to me and has a good warrantee on their stuff.
Old 06-18-2010, 06:35 AM
Thanks guys. I think when winters here and the car is garaged I'll look at Mosers then cause if someones got a decent warranty and their 2/3 price that cant be to bad a go
Old 06-18-2010, 10:50 AM
Wiki Edits: 49
The last set of axles I had shortened by Moser one came back wrong and they wanted me to pay shipping for them to fix it. Since the old man died the company isn't what it used to be especially in the quality department.
Old 06-18-2010, 11:25 AM
Oh great. So ya get a good warranty but because the qualities down I drown financially cause of shipping charges back and forth at the border. My canuk supplier wants 500 a set for dutchman as opposed to 295 from moser. The 295 is still cheaper after I've paid shipping and duty but if I got to pay shipping and duty over and over then I guess its the 495 touch for ol Doug
Old 06-18-2010, 11:59 AM
big gear head's Avatar
High Performance Rear Ends
I've been selling Moser stuff for about 13 years and very few of my customers have had any problems with their parts. I had one Camaro housing come in with the wrong spring perches and that's all that I can remember. As far as I can recall Moser paid to ship it back and fix the problem. I have had very limited experience with Strange. I narrowed a Strange housing once that someone ordered the wrong width, but that wasn't Strange's fault.
Old 06-18-2010, 02:54 PM
406 bug's Avatar
9.82 @ 139mph
Almost same problem. Ordered custom axles, they cut one too long; had to fight over shipping. I will not do bus. with them. Strange is worth the additional cost.
Old 06-18-2010, 03:47 PM
You can buy direct from Dutchman. I'm not up on shipping to Canada but you buy direct from them cheaper than 500 for the set.
Old 06-18-2010, 04:43 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I have had very good luck with Moser. If you don't order it right, it won't be right. My experience with Moser is a good one, no complaints.
Old 06-19-2010, 06:44 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
My axle did this (pic) a couple Saturdays back. I went to the Moser site and looked up the axle. Decided, cuz I like to know to check the measurement. Turns out I could not find the spline count and axle length that came out of the rear.
The following Monday I gave them a call, ordered what I needed . They said it would arrive that Friday . Friday night installed the axles and was driving the following morning ...
Moser is fine company to get parts from, their word is solid and make the promises happen .... Would recommend them to anyone interested . One other note to mention, usually a part manufacture will hose you on the extras. I will use bearings as the example, I found that was not the case with the Moser folks.
You will get what you pay for and the quality was excellent for this company .. Well done to them
Did I mention that they manufacture the parts right here, in what use to be good old USA .....
ID:	46290   Click image for larger version
Old 06-19-2010, 01:20 PM
Wiki Edits: 49
I forgot to mention that not only was one a little long (fixed it by grinding finally), but one of the axles had the wrong size retaining plate (Ford 9") which tells me they didn't even give me my original axles back. For some reason they didn't even bother to check to make sure the retaining plates were both the large size. Had to cut the small one off and use one of their retaining plate adapters just to get the thing installed. I would not recommend Moser to anyone. Curie or Strange but not Moser.
Moser or Inland Empire pinion yoke elcaminodragster Transmission - Rearend 2 07-05-2009 07:07 PM
A little disappointed with Moser Engineering's Customer Service Centerline Hotrodders' Lounge 5 08-24-2008 09:12 PM
Im sure that my rear wheels angle are strange...what you think Calderone Suspension - Brakes - Steering 12 06-05-2008 01:17 PM
Strange vs Motive Rear Gears, also which ratio: DTL504 Engine 4 04-28-2005 02:36 PM
Greg Moser Killed Benji Hotrodders' Lounge 1 05-19-2003 08:13 PM
