Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Strange noise???
Old 08-22-2004, 06:09 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
more
[color=yellow]Doc Here:
A bit more info please.
Is it a stick? And did you say it was a 455 Olds in a truck? What truck ? 2x 4x?
If it's a stick, It could be a throw ~out bearing, or bent finger on the clutch pressure plate.
On both transmissions, it could be a bolt has backed out of anything that rotates, Flexplate/Flywheel, pressure plate/torque converter, and is striking or rubbing something solid.
The Crank could have too much end play.
The Starter could just be hitting the flexplate/flywheel and need adjustment/shimming.
More info...and we can help more.
pimpoc
[/color]
