try a sticking lifter but that question was about as bad as mine.LOL,need more info is the kind of answers i usuall get and thats what it sounds like to me from your question but i could be wrong, my friends caprice has a spinning clattering sound when he hits the gas then he lets off it you hear the noise and he was told a sticking lifter.
More info is needed. Do you hear it at idle. or only when giving it the gas? Do you hear it standing next to the car when it runs?
Are you sure it's internal or maybe an engine accessory? Have you tried to put a stethoscope, or maybe a piece of hose or metal bar about the engine and tried to determine if the noise is internal to the engine or an accessory? Have you changed your timing chain, if it's an older engine? A worn timing chain rubbing its cover can make this sort of noise. Oh well, just some ideas. Good Luck! |
Sorry for the vague question. But i don't know what else to say except...... It seems to do it upon start up at idle and lower RPM. You can hear it standing outside the truck and also in the cab. I have listened and determined it is coming from the back passenger side of the engine, and am pretty sure it is under the valve cover. Thats why when i pulled the valve cover i would find a loose rocker or a broken pedestal, but i found nothing. Also, it is one of those annoying things i have been living with that it upsets you everytime you start it up then you blank it out while driving. So, i will drive around today with nothing else in mind to see if it goes away when it warms up. I think it does. Thanks 4 the replies.
more
[color=yellow][size=2]Doc Here:
A bit more info please. Is it a stick? And did you say it was a 455 Olds in a truck? What truck ? 2x 4x? If it's a stick, It could be a throw ~out bearing, or bent finger on the clutch pressure plate. On both transmissions, it could be a bolt has backed out of anything that rotates, Flexplate/Flywheel, pressure plate/torque converter, and is striking or rubbing something solid. The Crank could have too much end play. The Starter could just be hitting the flexplate/flywheel and need adjustment/shimming. More info...and we can help more. pimp oc [/color][/size]
Aftermarket Solutions Electronic & Electrical Innovations |
Yes, it is a 455 OLDS in a 1978 Chevy shortbed 2WD. It is an auto tranny. The starter is on the drivers side and the noise is coming from the passenger side. It has about 1000 miles on the engine now. Thanks!
Remove the flywheel cover, then start it , the flywheel could be rubbing it.
Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
uhhhh...ok....
![]() That could be the problem...look for a Very dizzy hamster in there.. ..LOLOr Barbed wire, car parts discarded someone along the road, rocks are always popular, and are in this season.. Doc [/color][/size]
one possibility is your lifters may bleed down after the engine sets for a while, they will usually pump back up though after running a few minutes, but when first started they may clatter a little bit.
Try key-on engine-off----Is your noise there? GM vehicles have the nasty habit of having the heater blower on low speed any time the key is on---stranger things have happened---
Hey cutlass and gismo, you need to check the dates on the threads before you post an answer.
We've all done the same thing. Troy __________________ If you don't make mistakes. your not doing anything. 69 SS/RS full custom Camaro 98 ISCA Grand Champion 69 SS/RS BB Camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 SS Chevelle BB conv.fresh frame off 26 T sedan street rod |
