Strange Noise/Strange Find - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2011, 07:41 PM
Missed a shift at the track last week and since then the engine has a misfire at speeds over 5500 RPM. Over last couple days, engine has developed a very strange, low pitched metallic clicking/thud sound in cadence with a single cylinder. Very strange sound, and removal/exam of the plugs didn't tell me anything. So, I removed the driver side valve cover and found the #7 intake pushrod had dislodged from it's rocker arm. The pushrod is not bent, and shows absolutely no damage to both ball ends. The rocker shows no damage, either. The underside of the aluminum cover shows a shallow concave spot, less than 1/4" dia where the pushrod was floating up and contacting it. The stud nut and lock were loose on the stud!
First, was it a coincidence that the noise and dislodging started right after the missed shift? Does it happen, from time to time, that the lock and nut can loosen and back off, causing the condition that I experienced?
Old 08-06-2011, 08:11 PM
bigdog7373's Avatar
Of course it's fast
Could it have been caused by excessive valve float because of too high Roma?
Old 08-08-2011, 06:47 PM
bigdog7373's Avatar
Of course it's fast
Sorry that should've said rpm. Lol autocorrect killing me
Did you figure out the problem yet?
Old 08-08-2011, 08:42 PM
Polylock split in two. When I went to assemble it and adjust the valve today........................the top half of the lock came off inside the wrench leaving the bottom threaded half on the stud. Got a new lock coming Wednesday from Summit.
Discussion has been alive on Speed Talk, so if you want to read the entire thread, you'll find it there under same title.
http://speedtalk.com/forum/viewtopic...321722#p321722
strange noise 72chevy240z Engine 5 12-13-2014 05:09 PM
strange trans noise Dainleljedal06 Transmission - Rearend 2 04-30-2006 07:51 PM
Strange noise??? gpeak Engine 13 08-27-2005 03:53 PM
Strange noise Camaro2Fast4u Engine 2 06-12-2003 02:05 PM
Strange noise dion Transmission - Rearend 2 12-16-2002 06:51 PM
