Strange oil pressure issues with ford 302
OK so I bought this 87 F-150 about a month and a half ago and it is having strange issues with the oil pressure. Most of the time its fine, while cold the needle is about half way between low and high. Pretty normal. After the engine warms up, its on the low side of the scale, but still within the "normal" range indicated by the gauge. This is with the engine fully up to temp.
Now here's where it gets weird. I can drive across town and back about 7 miles each way and the pressure is as described above. But get the truck out on the highway for a while, or drive across town and back twice, etc, it will usually (but not always) lose ALL oil pressure at idle. Might be some light ticking in the engine (not sure tho, its certainly not very loud like id expect if there was no pressure). Does this sound like bearings? And if so, why doesn't it do it all the time when its up to normal operating temp? Also it may not instantly lose all pressure, the gauge flutters for a second from about 1/4 way up all the way back down to zero and then it goes to zero and the engine light comes on. It does "sometimes" flutter the gauge at other times without the engine going to zero pressure.
I feel it is behaving rather strangely. Oil filter is a motorcraft filter. Miles on the truck shows 24k, but was told it was 124k. Not sure what weight of oil is in the engine right now, but i have some 10-40 to change it with as well as two bottles of STP.
Speaking of STP, it has two bottles of STP in it now, it did improve the situation some when i added them, but still acts up.
What do you guys think it sounds like?
