Strange sound from under truck!!!???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2009, 02:15 PM
dannyessexc's Avatar
BIG COUNTRY
Hello guys, I got a sound coming from under truck, itís like a rattling noise not real loud last about 3-6 seconds at different RPM's. It has no rhythm or consistency. it will do it at idle when I raise rpm to about 2000, then u let off or give it more it stops and same when driving, when it starts I can give it more gas or let off and it stops. I can't find anything loose that could make it. No vibration occurs with it. sounds like a small screw going through a fan. The only other noise that I get is a small vibration between 40-60 mph like a tire noise, but I got new tires and drive shaft looks good.
just got engine and xmission rebuilt, they sound good and can't here any noise from them, like the sound i here under truck. anybody got any ideas for me to check??? thanks
Old 04-05-2009, 02:55 PM
fast68's Avatar
likes chevy trucks & boobies
check torque converter bolts ? flexplate cracked ?
flexplate bolts tight?
got the lock washers on the bolts?
odd things happen
bolts come loose
flexplates will crack
had it happen on many, and many times over the years.
Old 04-05-2009, 02:59 PM
BIG COUNTRY
thanks!!!!! how much would new flex plate coast if it is cracked and thats something i can do with the haynes manual instructions i hope???
Old 04-05-2009, 03:14 PM
BIG COUNTRY
could the old starter be the problem since it wasnt rebuilt or replaced with the new engine and xmission
Old 04-05-2009, 03:20 PM
woodz428's Avatar
Troll Hunter
I'd lean toward the torque convertor bolts or possibly a loose starter. But some diagnosis of the vehicle first hand is the only way to narrow it down for sure.
Old 04-05-2009, 03:27 PM
McLeay F1's Avatar
Last journal entry: body work
could be a small piece of debris flying around in there, pull inspection cover trans. check starter engagement shaft, the spring could be worn, had the same problem on my old s10. could be anything
Old 04-05-2009, 03:28 PM
BIG COUNTRY
yea your right. i would be able to hear it coming from behind flywheel cover, if i got under with the old screw driver to ear method and let someone idle it up to i hear sound. i did it once with the naked ear and the loadest concentration was coming from right muffler, maybe something inside has vibrated loose??? i had to replace hangers the other day so the mufflers have been hanging slightly and rubbing frame little. just don't think thats the problem,(that would be to lucky for me..lol) thanks for your help
i will check all that ya'll have said, i gotta get the sound fixed before its something big.
Old 04-05-2009, 03:41 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What year and make truck are you working on?2 wheel drive or 4x4? cole
Old 04-05-2009, 03:46 PM
BIG COUNTRY
1997 chevy 4x4z71( engine and xmission has just been rebuilt 2weeks ago)
Old 04-05-2009, 03:59 PM
eloc431962's Avatar
Wiki Edits: 37
yea it can be alot of things the other post are all over it.so i would check those things and also check harmonic balancer and check the motor mounts incase its flexing making something rub.but if its doing it at idle also you really need to check the starter /flywheel/ and toqure bolts.hope this helps. did you pull the drive shaft a phisically check the u joints. cole
Old 04-05-2009, 04:04 PM
BIG COUNTRY
no, its time for new u joints they havent been replaced in some yrs. i was gonna replace them anyway here soon
thanks
Old 04-05-2009, 04:10 PM
eloc431962's Avatar
Wiki Edits: 37
give them a look then see what you got.could very well be your vibration and causing a rattle somewhere on you truck.let us know what you find and if we can help anymore. cole
Old 04-05-2009, 04:30 PM
BIG COUNTRY
i will and this site has by far been the best to reply back, just wish i had the knowledge u guys have so i can help folks out!!!!
thanks again
Old 04-05-2009, 05:38 PM
powerrodsmike's Avatar
Wiki Edits: 161
Things do come loose inside catalytic convertors and mufflers..then they ratle with no apparant consistancy...A good way to check those is to shut the truck off, and lay underneath and hit the pipes, mufflers, etc sharply with the heel of your hand or a soft rubber mallet..Then listen for a rattle that sounds the same. That's how my next door neighbor ,(muffler shop), checks for rattles in the exhaust system...Those heat shields come loose too, and rattle at certain RPMs sometimes.
Just a thought.
Later, mikey
BE different....ACT normal.
Old 04-05-2009, 05:48 PM
BIG COUNTRY
tired to bang on it with hand, no sound, but with the new hangers they dont move at all, will try with rubber hammer!!!!. dont have cats or heat shields....lol took them off the last time they made a rattling noise
thanks
My new(used) truck 1931 steve Hotrodders' Lounge 5 09-02-2006 12:54 PM
Diesel truck, should I buy it??? 1931 steve Hotrodders' Lounge 4 08-07-2006 08:34 PM
1951 Truck For Make A Wish MINING CAMP Hotrodding Basics 0 05-08-2006 08:00 PM
replacement pickup truck - your advice please jojo99 Hotrodding Basics 7 05-03-2006 11:52 PM
Investigating Strange Engine Sound horvath Engine 15 07-15-2003 10:56 AM
