strange th350 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2005, 04:05 PM
Hey guys,
I frequently read the boards but rarely post, but im just plain stumped so thought I would ask for some help. A little history:
I had what I believe to be a 1978 Olds 403 SBC motor mated to a th350 transmission. The transmission had a lot of metal shavings in the pan, so I figured I should swap it out. So I purchased another th350 from a local hot rod swap that was a fresh rebuild. Motor and tranny went together fine. 6 months later, I blew the motor.
So I had a 350 sbc sitting in the corner and figured it was a good time to start using that. So I yanked out the 403 and stroked the 350 to 383. The 383 is a 1974 block, so i figured the transmission would fit the new motor. But I seem to be wrong. Rather than encountering the common problem of having too much space between the flexplate and converter, I have the opposite problem. It 'feels' like the transmission is properly seated on front shaft. I called the shope I bought the stroker kit from (and the shop that did the machine work on the motor) and both say I shouldnt have any problems. I have tried 3 different converters and none of them fit. I still have ~3/4" between the bell housing and the block after the converter is seated against the flexplate.
Any suggestions would be GREATLY appreciated. Sorry to be long winded but i am pulling my freaking hair out, so I have come to ask the you guys who know way more about this than I do. thanks!!
-49chevysd
Old 09-16-2005, 04:21 PM
ronb's Avatar
I`am thinking the converter is not engaged with the pump gear properly! push the converter into the tranny while rotating it in either direction! when it engages the two notches in the hub end the converter should be recessed about and inch behind the tranny bolt face? bolt the housing to the block, then move the converter forward to the flexplate
Old 09-16-2005, 04:28 PM
thanks for the response
Ive taken that thing in and out so many times. Ive never had that much trouble seating a converter!!! Any other possible reasons than I just havent got it seated correctly?? thanks..
Old 09-16-2005, 04:38 PM
ronb's Avatar
you do not have to take it out! just turn the converter with your hand while pushing it to the pump! from what you wrote i cannot tell if you have the converter bolted to the flex plate now? if you do? you have to unbolt it push it back and then align your bell housing to the block/bolt it up then pull the converter up to the flex plate and bolt it up! if you did this already there must be and interference issue somewhere??
Old 09-16-2005, 04:41 PM
the transmission is sitting on the floor in my garage and isnt currently bolted to the flexplate/motor.
Old 09-16-2005, 04:43 PM
ronb's Avatar
is the converter in it now?
Old 09-16-2005, 04:50 PM
the converter is "in" it in the idea that it is on the shaft and from what it sounds like it just isnt engaged. Ill check it out when I get home and let ya know. thanks for the suggestion.
Old 09-16-2005, 08:25 PM
Ricky Rocket's Avatar
Drive it like a rental!
The simple way to know if the converter is in far enough is to try to fit your fingers behind the converter. If you can fit your fingers between the converter and the pump, it is not seated. If your fingers will not fit, it should be in.
If you tried to force the engine and trans together with the bell housing bolts, you may have damaged the pump.
Rick
Old 09-16-2005, 10:47 PM
actually the old housing was cracked. I had a transmission shop here swap the internal components into a fresh case. The shop who primarily builds race transmissions said everything was tip-top. but ill try the "finger test," i havent tried that yet. good idea...
Old 09-16-2005, 11:46 PM
49chevysd,
Could the flexplate be on backwards?
Scholman
Old 09-17-2005, 09:56 AM
i thought of that too. But isnt the SFI sticker supposed to face the transmission? And when I flipped it, the converter no longer properly met the bolt holes.
Old 09-17-2005, 10:45 AM
well i tried to fit the converter into the tranny this morning and i noticed something strange. looking down the front pump into the tranny, it doesnt look like the keys are directly across from each other. Is it possible for them to somehow come out of alignment? On the converter of course the keyholes are directly across from each other, but it doesnt look that way inside the transmission. thanks for any help!!
Old 09-17-2005, 12:38 PM
Those two tabs are part of the oil pump inner gear, and this is all one piece. If they aren't directly opposite each other, the gear must be broke. I am a little confused on the cracked case, did this happen trying to force the engine and trans together? If so the pump gear is probably also broken. If you are unsure about the pump you should take the trans to a shop and have them inspect it. They shouldn't charge you anything if it is OK and doesn't need to be taken apart. If the gear is broke, make sure they inspect the whole pump or put in a rebuilt pump.
Good luck,
Rick
Old 09-17-2005, 01:00 PM
ronb's Avatar
Good luck,
Rick
you can insert a small pick and try to rotate or move the tangs to see if it is still in one piece
Old 10-09-2005, 10:59 AM
Pump gears
Hey, what's going on with your dilemma? Are the pump gears broke, or are they in back wards? What did you find out?
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
Strange problem with ignition...... talunceford Engine 5 11-08-2004 06:25 AM
th350 + kickdown + problem sbc350 Transmission - Rearend 15 01-26-2004 01:08 PM
TH350 Manual Low Problem HELP! andrewhotrod Transmission - Rearend 3 01-25-2004 10:25 AM
th350 speedometer problem john69 Transmission - Rearend 4 06-17-2003 06:38 PM
