If it is a fisheye problem that didn't show on the first coat of clear then you may have an airborn contaminant that settled on the first coat of clear before applying the second coat. Did you turn the Booth/fan on and off? Could the airflow have picked up any contaminants between coats? Think about what was going on between the two coats that may have caused your air to pick up something. Are you sure it isn't moisture in the lines? If they are really small in size and very numerous I would guess it to be solvent popping.
