Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Strange thing happening with my clear "solvent pop"/"fish eyes" ?
Old 03-28-2005, 04:07 AM
BarryK's Avatar
BarryK BarryK is offline
Outside temp is about 45*
Shop temp is a steady 65*
Metal temp---- ?
That is one thing I didn't think about.......the metal temp, but the shop was heated to 65* 2 hours befor painting......however I was doing some light wetsanding to, so I'm sure the water would have kept the metal temp d************************************************* *******
If shop was warmed to 65 in 2 hours no way metal temp was even 55. It takes metal temp many hours to warm up. This is common problem in winter,
The first coat of anything sprayed on the cold metal will flash and the solvents against the metal will set there. Most likely like discussed earlier all your solvent is coming from first tack coat of base and cold metal.
