Strange turn sig./ brake light prob. solved - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2010, 03:26 PM
406 bug's Avatar
9.82 @ 139mph
I recently ran into a strange problem. I was very careful when doing the wiring of my rear lights on a recent build. When doing a final check, found the brake lite was coming on thru the lense where the turn sig. was originally and turn sig. where the brake was. Simple problem right. reversed wiring- no fix. Turns out - fender was not making proper ground to body - causing the lights to reverse!! I don't have the expertise of many on this board- but I really thought this was weird. Maybe this will help someone not to pull their hair out as I did!
Old 06-09-2010, 09:13 AM
DOCTOR DC's Avatar
NUCKINFUTS MOTORSPORTS
Welcome to the path of least resistance...............
Old 06-11-2010, 12:28 AM
fast68's Avatar
likes chevy trucks & boobies
ground is so important.
if you dont then real funny things happen with lights and filaments etc.
you just cant have too much ground! more the better!
especially for lighting systems!
Brake light problem mightycarlo10 Electrical 6 12-18-2007 05:43 PM
Brake light on when the headlights turn on Techguy_2000 Electrical 2 10-21-2007 11:47 AM
What will cause the BRAKE warning light to come on? colin911 Engine 5 09-01-2006 03:00 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
brake light prob woodysracing Electrical 8 04-30-2002 11:19 AM
