Strange vacuum line hookup to modulator on T-400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2013, 07:06 PM
MJS69's Avatar
Hi all
I'm in the process of fixing a bunch of halfa$$ed work the former owner of the car did, and the vac modulator line was on the list... (vac modulator on a TH400).
The line comes off the vacuum tee on the intake manifold, and rather than go directly to the modulator, it attaches to one end of cylinder (about 4 inches long and 1 1/2 in tall) and then out the other end of the cylinder to the modulator. In addition to this vacuum line, the cylinder is plumbed into the transmission fluid cooling lines on both sides.
What the heck is this cylinder thing, and why does it have vaccuum hooked up to it?
Old 05-20-2013, 07:14 PM
Banned
photo, and what are you working on??
the log, might controll trans cooling flow while pto in use
Old 05-20-2013, 07:35 PM
MJS69's Avatar
Transmission is not original to the car (a '79 trans am), but the TH400 transmission is out of a '78 GM pickup I believe...not sure though. I'll try to get a pic of it tonight.
Old 05-20-2013, 08:53 PM
Banned
was it a turbo t/a , mod. valves don't like boost
Old 05-20-2013, 10:34 PM
MJS69's Avatar
no, it was originally an Olds 403/TH350 equipped car, the previous owner had swapped in a chevy 350/TH400 combo. Pretty common nowadays to see T/A's that had olds 403's get replaced by a SBC when the 403 blows up because the olds are hard to find, parts are expensive, and they are crap engines to start with anyways.
Pics comming soon...about to go back under the car.....
Old 05-21-2013, 09:50 AM
MJS69's Avatar
mystery solved...it turned out to be a homemade heat sheild the PO had fabricated to protect the lines from the headers...
Vacuum hookup on T-400 transmission? Juleshulings Transmission - Rearend 4 02-08-2013 09:59 PM
Fuel in vacuum modulator line Yegster Transmission - Rearend 9 06-23-2011 08:20 PM
Vacuum modulator hookup for automatic 65malibuSS Transmission - Rearend 2 11-29-2010 11:27 AM
T-400 modulator line unstable Transmission - Rearend 8 04-12-2010 06:30 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 03:25 PM
