Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Strange Voltmeter Issue
Old 08-16-2012, 08:17 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: LED tail lights
amps
That model car/year had an ammeter not a voltmeter.
I believe you are seeing an amp draw that is causing the ammeter to go below 0 amps.
Check the dome light for shorting to ground. I would expect that a fuse would blow on the dome light circuit or you could remove the fuse and the problem will go away.
vicrod
