Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Strange Voltmeter Issue
Old 08-18-2012, 07:29 PM
dogwater dogwater is offline
Last journal entry: Still running strong
Dome light-Replace the switch that the door pushs on when closing the door.Some where I read that when you change out an amp gauge an put in a voltage gauge it a big no no to connect the volt gauge the same way as the amp gauge was.What I would do is disconnect the gauge connect your volt meter to it an see if it acts like a voltage gauge,such as turn the key on,read voltage then turn on the head lights,should be a volt drop,then start it up should be a volt rise.If it doesnt do that then sump tins f-up.
