I don't know if a 56 Chevy uses a panhard bar or not. I doubt it, as I think it was a coil-spring thing.
This panhard bar (if equipped) attaches to the top of the diff using a fairly large diameter (5/8"?) stud, and a similarly large bolt to a bracket on the frame. There is a rubber bushing in each end of the bar. Here is a picture of my 66 GMC frame. The panhard bar is the round yellow bar attached to the rear diff. If so equipped, and yours has broken loose (bushing disintegrated?) it would allow a fair amount of side-to-side rear axle travel.
I thought that he said it had leaf springs...read the first post...thats the way I understood it anyway.
If he does not have the after market sway bars I would suspect a high speed turn as the body roll is extreme on these trucks.I drove a 59 apache daily from 1976 to 1989 without sway bars but most of my tire problems were from the inside of the tire rubbing the wheel well. but I ran a narrow 7.50x16 truck tire.I run 31x10.5 15s on the 58 Apache I drive now and had a mild rubbing issue in corners till I installed the sway bars front and rear.It handles better than my 97 Chevy now and no rubbing issues for 2 years.
It is possible that he kicked up something that caught in the wheel well and rubbed the tire and then dropped out. Chances are that if had happened to me when I was young the damage would have been from rubbing a curb real hard or doing something else stupid. I wouldn't have owned up to it either or I wouldn't have noticed.
| Strange vacuum problem | JohnyR17 | Engine | 8 | 03-16-2006 04:05 PM |
| Strange noise in Powerglide | woody51 | Transmission - Rearend | 2 | 08-20-2005 02:22 PM |
| Strange vs Motive Rear Gears, also which ratio: | DTL504 | Engine | 4 | 04-28-2005 01:36 PM |
| strange idle | brad11957 | Electrical | 3 | 12-21-2004 12:23 PM |
| Strange Auto Parts | brandler | General Rodding Tech | 4 | 09-14-2003 10:35 PM |
