Engine 2 does not have enough compression to take advantage of aluminum's greater rate of heat transfer to the cooling system. You want an engine that runs the dynamic compression into the 8 to 1 range, especially with aluminum. The lower the compression the higher the cost both in lost mileage and power. Aluminum easily will carry a full ratio or more against that of cast iron for the same octane fuel. With the modern fast burn chambers of the E-Street head, these should be happy with 87 unleaded. The 270 degree cam of engine 1 is probably unnecessary, the Comp 268 or better for your RPM goals the 262 would be fine. The 262 would bolster low to mid RPM torque and has surprisingly little loss of top end power against the 268. Longer rods would improve the mid range and make the engine even more tolerant of running at what is essentially lugging RPMs without getting into detonation. Bogie |
I like the idea of a smaller cam, but I think I'll already have plenty of torque, and my rough calculations of the effects of a smaller and/or more advanced cam installation kind of scared me, due to the dynamic compression quickly looking unsuitable for 87 octane. Anyway, it's all food for thought. This build is a few months off; today was the first day I've really penciled anything out. Thanks for the input! |
Bogie mades some great points and that 400 will like a lil more compression! and a longer rod!
Heres a few pics of my 406 going together 1970 400/406 4bolt srp studs Internally balanced Scat 3.75 crank Scat 6" rods Mahle Forged flat tops with 2 valve releifs 7 quart pan melling select pump Cloyes true billet double roller with torrington bearing CSR billet pump SFI dampner Billet Specialties pully Lunati solid roller 243/249 @.050 595 " lift Pro-Filer Aluminum heads 210 cc 2.05-1.60's 1.5 lunati roller rockers PP Huricane ported to heads 750 Mighty Demon 1" Billet HVH 4 hole spacer MSD Billet ignition components Smooth runner fender well headers 3" Magnaflow exaust
| Why I have grown to hate the Small Block Chevy..... an essay | Centerline | Hotrodders' Lounge | 316 | 02-08-2012 10:46 PM |
| 400 sbc vs 400 pontiac | Artemis Entreri | Engine | 52 | 09-08-2010 06:17 PM |
| Critique my 406 SBC build | Chevtec | Engine | 9 | 03-13-2010 02:37 PM |
| 400 cid SBC | Shades_o_Grey | Engine | 20 | 02-04-2008 12:28 PM |
| 400 - sbc | gilby246 | Engine | 4 | 10-19-2006 10:44 PM |
