Street 454 build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-20-2005, 10:22 PM
Originally Posted by bracketeer
These are a very expensive piston. Speed pro makes a reasonably priced open chamber forged piston that will give you about 10.25 comp. It is similar to the SRP piston made for the Edelbrock head but costs less. I also prefer the Crane 284 H12 cam, .544 lift 284 duration for a street car. Use it with 3000 stall and you will smoke the tires at 40 mph.
hey bracketeer how much of a pop up is that piston?i have the option of 049 or 781 heads and if im right they spec out at around 120cc chambers.Another point you brought to my attention is the stall speed,if i decide later on down the road to put a overdrive tranny in the car,lets say a 4l80 which say puts me at a cruize rpm of 2500,will the tranny overheat do to slippage running with a 3000 stall?
Enquiring minds want to know
  #17 (permalink)
Old 06-21-2005, 02:29 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
answer
With a .030 bore. Jegs lists the Speedpro piston here. Part #844-L2372AF30. This gives you 9.6 comp at $39.99 per piston. The SRP piston will give you 10.0 comp but is more expensive. When you look at Jegs you will notice the next size piston for 10.3 compression is over $80.00. The same for the .100 piston that was recommended earlier. I run the 100.9 head so I get 11.3 compression with this piston. Since I have so much torque, no detonation on pump gas.
Higher stall creates more heat. A tranny cooler is certainly recommended. B&M make affordable, reliable products.
bbc 454 maximum power engine build up rynophilia Hotrodding Basics 12 05-18-2015 11:24 PM
street rods Robert Podgurski Hotrodders' Lounge 18 11-27-2008 05:18 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
Looking to build an engine this summer Jms8800 Hotrodding Basics 44 06-21-2004 10:34 PM
