Street Beast 34 Ford door hinge - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2013, 10:57 AM
Recently, I have had a problem shutting the drivers door. I was told by a body shop that it appeared to be a bent bottom hinge. Please advise where I might could find one.
Old 05-30-2013, 11:06 AM
I have to tell you, not seeing your car, just the sound of this is all wrong. You have a fiberglass body, with a metal hinge and the hinge is bent? Not without breaking the glass! The metal hinge is stronger than the body so how could the hinge get bent without damage to the body? Post some photos and let's discuss this.
Old 05-30-2013, 11:39 AM
Thanks Brian. I kind of felt that they were blowing smoke and didn't want to mess with it. Actually, lately I noticed that the door wouldn't "snug" up as usually. It seems to be binding. I can still close, insert the suicide pin .
I think I will get my mechanic to look at it...not being a gear head, I have to see what he says. Will let you know. Jim
Old 05-30-2013, 11:59 AM
The problem is, the bodyman is the guy who would be the go to guy for that and the mechanic will commonly not have a clue.
Maybe find another bodyman.
If you posted some photos of where the hinge mounts and what not. It is likely it could be adjusted out the door is probably sagging little. This doesn't sound so good with a glass door but it could be just a little and you could adjust it back to work. Without seeing anything it's hard to say.
Old 05-30-2013, 12:06 PM
life is a temporary assignment
It takes a while to get them doors right,, They was made wrong,,, But you can do it..
Old 05-30-2013, 12:38 PM
Thanks, good advice. It's not much. Jim
Old 05-30-2013, 02:24 PM
The common problem is the rear of the door sagging, the latch starts hitting too low on the striker. Just plain old wear, just like any car. Bring the upper door forward or the bottom of the door back, that raises the back of the door.
If you post some photos with the door just about closed showing the gap to the body at the front we should be able to walk you thru it.
Old 05-30-2013, 04:28 PM
Banned
all your Street Beast Problems and fixes!!
Street Beast builds......Tips, problems and solutions.
Old 05-30-2013, 10:39 PM
35terraplane's Avatar
Behind the fiberglass "B" piller is a steel post,the hinge bolts to that. In the door is a steel plate which the other end of the hinge bolts too. The glass in the door is quite beefy.
On mine I had to shim the hell out of it. then I mic'ed the shims and machined one the right size. One side took more shims than the other.
I would think you could oblong the holes in the plate that holds the post to move it forward and back, but I think that would be the hard way.
Like randy said they take a little playing with but you can get them so they look good.
Bob
1934 Street Beast Ford Coupe karykeen Introduce Yourself 11 11-24-2015 02:22 PM
door hinges on 41 willys street beast bdogg6 Body - Exterior 6 01-16-2013 07:29 AM
door hinge pin removal 31 ford twin-pipes Body - Exterior 6 03-29-2006 09:12 PM
46 Ford door hinge problem woody51 Body - Exterior 4 09-11-2003 11:03 AM
46 Ford door hinge problem woody51 Electrical 0 09-10-2003 03:42 AM
