Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Street Beast builds......Tips, problems and solutions.
  #168 (permalink)
Old 05-31-2011, 04:00 PM
ffas23's Avatar
ffas23 ffas23 is offline
Originally Posted by brickyardboy
If you happen to access those rear shock numbers, that would be great! Are you happy with the ride you get with the Gabriels? Wish I had a damn lift! It would make things so much easier on this old body!
I felt the same way as I didn't have a lift right away when building my car back in '92 but put one in soon after in '93. Glad I still have it today being I am 60 years old now and can't imagine what it would be like to not have that lift today as I use to do a lot of crawling underneath plenty of cars back in the day. The ride is not bad but as I mentioned early on because the Fenders should of been a little wider from the factory using a Mustang Rear with 2 heavy people in the car I had some rub issues with the tires so I installed air bags in the stock '89 LX Rear Springs for if and when I needed them. I am 250 pounds and don't have any problem by my self but put someone else in the car with that kind of weight I then have a problem and rely on the air bags. Ride is not too bad otherwise. Got a good road to drive on, no problem.
