Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Street Beast builds......Tips, problems and solutions.
  #344 (permalink)
Old 12-14-2012, 03:54 PM
dhvoorhees dhvoorhees is offline
48 Ford Pickup, 34 Ford Coupe
Door Hinges
Originally Posted by snowraker View Post
I am in the process of hanging my doors on my Vicky. If you are anywhere near Oklahoma, you are welcome to come and look at them or I can try to draw them up for you. Mine are already mounted on the car, but I can take one off for a sample to look at or send pics. I doubt that Hagan or anyone else is going to get you what you need. Although they are very simple, the angles and bends are critical to good fit and function.
I'm in Maryland so Oklahoma would be a bit far to come out and see it in person. All of the pictures here are really helpful, so I think I can get them made easily. . Thanks for the offer. Do you have the angle of the hinge between the door and the jam. It looks like it's about 45 degrees.
I just stopped by the local metal supply company on my way home from work and they had scrap pieces of 1/4" that would work fine. They used the "Break Cutter" and made me the correct width and length of material. I just have to get the angle bend just right and drill out for the mounting bolts. Got the round tube also so I have to just weld the round tube for the door hinge pin.
