Used Engines
There was a time when I wouldn't even think about using a junk yard engine, but in recent years there are some amazing engines priced very reasonable at wrecking yards around my area. For instance the GM LS engines have in excess of 300 hp, come with an OD transmission for less than $2000 anywhere between 50K and 80K miles. Nothing wrong with a 2007 pickup engine and transmission with 50K to 80K miles on it, still well over 100K miles left. Both Ford and Chevy engines and transmission combos are available at wrecking yards that are pretty darn nice. There are several companies that make wiring harnesses that are easy to install.
I didnt know that Streetbeast made a Vicky kit.......Saw this ad for a car for sale up here....
http://ontario.kijiji.ca/c-cars-vehi...dIdZ270715905# 1933 Ford Vicky 1 piece fibreglass kit made in 2002 by Street Beasts. Mustang II front suspension, 8.8 posi rear, brand new GM ZZ383 aluminum head stroker motor, B&M TH-350 transmission, Edelbrock air gap intake, Holley carb, MSD 6AL box, MSD billet distributor and coil, front spindles, front brake pads and rotors, rear panhard bar, front sway bar. Car has less than 100 miles on drivetrain. Looks and runs incredible. Make you friends jealous and scare Grandma. Turn key killer Hot Rod ready to Rock n' Roll. I may consider possible trade on Harley Trike. Please call Randy at (905)701-****
Ontario Rodders |
The one you are showing is going for a lot of money. Doubt if the seller will get that kind of money or anything even close. He must not be happy with it only putting about a hundred miles on it or thinks he can make a lot of money on it by selling it. |
Yeah - there are a couple that I see at NSRA/Burlington every year. They are fairly well done, but to me, look ----- different
Dave W |
Can anyone suggest what rear shocks I should use on my '34 'beast coupe? It presently has air shocks (don't like the ride) and I blew out the right rear this past Sunday while tooling along on our horrible New England roadways. Maybe a coilover?
What kind of bracketing is under the car? And second what's the weight balance? What is the angle at which the shocks will be mounted? And last, what is the distance between mounting points? But to answer YOUR question, coil overs work very nicely and might be a good choice for replacement.
The reason I ask those questions is so a specific length, mount type and spring rate can then be discussed. If you have pictures, better yet. Brand name - that will your choice though I did have some poor luck quality wise with some QA1 springs. Dave W |
[QUOTE=ffas23]If you built your car according to the manual using a stock rear end out of a Mustang that they recommended in the manual it gives you the part number for a shock to fit the rear on these cars. I crossed the number over to a Gabriel Shock I remember but right now I don't have access to that part number. If you need it and don't have your manual just let me know and I will try to help you out.[/QUOTE
I didn't build the car. This is my wife's car. She liked the color, so that's why she bought it almost 2 years ago. LOL It could have been a Yugo, and if it was "raspberry" color, she would have bought it! A lot of things I would like to change, but I won't because of the market value of these cars. So we'll keep it. Anyways, I don't have a manual, but this has an 8.8 rear end with 4 lug axles, so I'm assuming that it's Mustang II. If you happen to come across that shock part number from your manual, I'd appreciate it. Thanks for the help. |
![]() Mine - I now have 200lb springs at vertical, 188# effective at 13 degrees inclination. Weight wise, the '32 gas tank, the added frame extension and the Optima battery add the weight to the rear of my '31 and is nicely stiff, but not jarring. Dave W |
I went back through my file of paperwork from when I started building my '34 Coupe and found the Gabriel Part number for the Front and Rear shocks as I remembered the warehouse I purchased them from also. Don't know if they even make the part numbers anymore but someone from Gabriel if you contact them should be able to cross it to another shock. Ok I am going to give you the Part Numbers I have as I have 2 receipts for Front Shocks and Rear Shocks. Problem is I don't know which receipt is for the Rear Shocks or Front Shocks as they don't tell you on the receipt. The first receipt is dated 10/13/92 and listed on it is Gabriel Red Rider 82128 or 81106. One I assume replaced the other in the lineup. The second receipt dated 10/29/92 shows Gabriel Gas Red Rider 81461. I remember both sets Front and Rear were gas shocks just don't remember what part numbers listed here are Front or Rear but I am sure if you call Gabriel they should tell you what was what back then. Hope this helps. I believe the rear you have could of come out of a later Mustang being the '89 Mustang LX rear that I put in my car had 4 lug axles at the time but now have 5 lug axles.
BrickyardBoy, If it helps I am going to put my Street Rod up on my lift later this week and can take the part number right off of the Gabriel Rear Shocks to help you know what ones are the rears based on the part numbers I gave you. Right now my lift is tied up with my wifes Intrepid on it being I am waiting for a ABS Sensor for the left Front of her car. Had 2 shipped out to me and they arrived on Saturday but what always seems to happen to someone like me of course someone switched one of the part numbers in one of the boxes or returned it with the wrong ABS Sensor inside of it so I was only able to do one side and with the Holiday weekend I am forced to wait a few more days for the correct ABS Sensor to arrive depending on were it is being shipped from.
| Recent Hotrodders' Lounge posts with photos |
| street beast | Kirk Gregory | Introduce Yourself | 3 | 09-04-2008 06:49 PM |
| street beast | Kirk Gregory | Introduce Yourself | 1 | 10-05-2007 10:42 PM |
| My 33 Vicky Street Beast | Fred Martin | Introduce Yourself | 4 | 12-06-2006 02:49 PM |
| Street Beast 41 Willys | bobthetran | Hotrodders' Lounge | 17 | 05-04-2006 11:14 AM |
| Street Beast Company | Dave E Shank | Hotrodders' Lounge | 6 | 10-02-2003 10:02 AM |
