And, another one:
ROD RETAIL PRICES
BOX # 1
Part # Product Description QTY. U/M TOTAL RETAIL
24-0270-00 HINGE CLEVIS PIN 4 EA $54.00
24-0124-00 DOOR HANDLE PLATE, CAB, '34 2 EA $40.98
34-0350-00 TRUNK HINGE: ALL RODS 2 EA $37.92
24-0076-01 HINGE ASSEMBLY; ’34 RODS 4 EA $132.00
24-0046-00 STRIKER POST BRACE, LH: ’34 1 EA $9.30
24-0047-00 STRIKER POST BRACE, RH: ’34 1 EA $9.30
24-0801-00 BRKT, UP LH RAD MNT: ALL RODS 1 EA $15.30
24-0803-00 BRKT, UP RH RAD MNT: ALL RODS 1 EA $15.30
24-0043-00 DECK LID HINGE BRKTS: ’34 2 EA $88.74
24-0044-00 DECK LID HNG ANGLE, LH: ’34 1 EA $27.00
24-0045-00 DECK LID HNG ANGLE, RH: ’34 1 EA $27.00
24-0059-00 WINDOW CHANNEL, ADJ. RH :RODS 1 EA $67.50
24-0061-00 WINDOW CHANNEL, ADJ. LH :RODS 1 EA $67.50
24-0002-00 LOWER WINDOW CHANNEL: ’34 2 EA $67.50
24-0089-00 BRACKET UPPER HINGE POST:’34 2 EA $19.14
24-0690-00 SUPPORT, BUMPER TUBE : ALL RODS 4 EA $156.00
24-0077-00 REAR QRTR BRACE, RIGHT: ’34 1 EA $47.79
24-0078-00 REAR QRTR BRACE, LEFT: ’34 1 EA $47.79
24-0003-00 SEAT TRACK BRKT: RODS 4 EA $131.04
24-0300-00 BUMPER BRKT, FRNT: ALL RODS 2 EA $95.58
24-0305-00 BUMPER BRKT, REAR: ALL RODS 2 EA $95.58
24-0041-00 FENDER SUPPORT, RH: ALL RODS 1 EA $18.00
24-0042-00 FENDER SUPPORT, LH: ALL RODS 1 EA $9.90
24-0640-00 BRKT, DOOR MOUNTING POST:’34 2 EA $8.10
24-0216-00 HOOD HNG MNY TBE CUT: ALL RODS 1 EA $54.60
24-0221-00 HOOD LOCK TUBE, CUT: ALL RODS 1 EA $81.90
24-0226-00 HOOD HINGE ANGLE: ALL RODS 1 EA $68.25
24-0230-00 HOOD LOCK ANGLE CUT: ALL RODS 1 EA $54.60
TOTAL 48 $1,547.61
BOX # 1 Continuation
Part # Product Description QTY U/M TOTAL RETAIL
24-0092-00 HEADLINER FRAME, LH:’34 ROD 1 EA $36.00
24-0093-00 HEADLINER FRAME, RH: ’34 ROD 1 EA $36.00
24-0079-01 HINGE POST LH: ’34 COUPE 1 EA $86.25
24-0081-01 HINGE POST RH: ’34 COUPE 1 EA $86.25
24-0091-00 HEADLINER FRAME, FRWRD: ‘34 1 EA $48.00
24-0094-00 HEADLINER FRAME, CNTR: ’34 1 EA $33.75
24-0082-00 RH, DOOR STRIKER POST : ’34 1 EA $54.00
24-0083-00 LH, DOOR STRIKER POST: ’34 1 EA $54.00
98-0004-00 SEAT TRACK MOUNT PLATE 4 EA $156.00
TOTAL 12 $590.25
ROD RETAIL PRICES
BOX # 2
23-0075-00 FRONT/REAR BUMPER: ALL RODS 2 EA $934.44
TOTAL 2 $934.44
BOX # 3
85-0315-00 HOSE GAS, FILLER 1 ½” I.D. 4 p/inch $71.64
24-0344-00 FELT WINDOW CHANL. 750000073 1 SET $48.00
26-0015-00 INTERIOR 1 EA $882.00
22-0026-00 CARPET SET, ’34: ____________ 1 SET $343.62
34-1535-00 TRUNK CABLE: ’34 #100-022 1 EA $29.10
24-0269-00 WASHER, 3/8”, STRICKER BOLT 6 EA $1.08
24-0276-00 DOOR HANDLE LINKAGE: ’34 2 EA $8.28
23-0161-00 DOOR HANDLE RTRN SPRNG: ALL 2 EA $31.08
23-0121-00 LATCH , DOOR, RH, TRMK #11656-16 1 EA $30.00
23-0122-00 LATCH, DOOR, LH, TRM K#11657-16 1 EA $30.00
23-0126-00 TRUNK LATCH TRIMARK #11789-16 1 EA $30.00
24-0765-00 ROD, DOOR RELEASE, INNER: ALL 2 EA $19.50
24-0264-00 HOOD LOCK ROD (19”): ALL 1 EA $5.55
24-0279-00 SHIM, DOOR HINGE: RODS 12 EA $1.80
24-0263-00 HOOD RELEASE ROD: ALL 1 EA $5.10
23-0015-00 TAIL LIGHT (81A13405): ALL RODS 2 EA $53.16
23-0130-00 CAM DOOR HANDLE 2 EA $8.40
24-0235-00 HOOD LOCK STRIKER: RODS 2 EA $36.00
24-0240-00 HOOD LOCK BOLT: ALL RODS 2 EA $28.92
23-0164-00 STRIKER BOLT: ,3/8’-16X3 ¼’ L 3 EA $2.88
24-0245-00 HOOD LOCK SPRING: ALL RODS 2 EA $5.40
24-0255-00 HOOD RELEASE SPRING PLUNGER 2 EA $16.08
24-0260-00 HOOD RELEASE ROD END SPG-1002 3 EA $8.55
23-0171-00 BUSHING, 3/8”IDX1/2” ODX1” L 3 EA $8.10
24-0267-00 HOOD RELEASE ROD HANDLE 1 EA $12.18
26-0401-00 DOOR HANDLE, LOCK SET:RODS 1 SET $55.20
23-0160-00 HOOD HINGE, HIDDEN #20526D-B 2 EA $37.86
24-0325-01 GAS CAP/FILLER:’34 1 EA $51.93
23-0020-00 GASKT, TAILLGT(81A13520):ALL 2 EA $3.84
TOTAL 65 $1,865.25
BOX # 3 Continuation
24-0250-00 HOOD LOCK ROLL PIN 3/16” X 1” 4 EA $1.44
24-0350-00 HOOD/DECK LID ADJUSTER #4375 2 EA $35.70
24-0360-00 A12909 UPHOLSTERY FASTENER 30 EA $13.50
23-0150-00 DOOR/WINDOW SEAL #4515 25 p/ft $62.50
23-0116-00 WINDOW CRNK CHRM: ALL 2 EA $23.70
24-0750-00 SEAL, COWL RUBBER 1/8” X 1” RODS 12 p/ft $28.08
ROD RETAIL PRICES
24-0355-00 DOOR SEAL RUBBER #75001745 26 p/ft $97.50
23-0145-00 BUTYL TAPE (5/16”) 15 p/ft $6.30
23-0140-00 RUBBER WINDSHIELD TRIM: RODS 10 p/ft $60.00
23-0027-00 WINDOW REGULATOR, RH: RODS 1 EA $137.85
23-0026-00 WINDOW REGULATOR, LH: RODS 1 EA $137.85
23-0400-00 PARKING LIGHT 2 EA $28.50
03-0380-00 HEADLIGHT HOUSING 2 EA $105.00
05-0685-00 WELTING, RUNNING BOARD (10’) 1 EA $8.40
34-1610-00 DOOR RELEASE MECH, INSIDE, L/H 1 EA $32.85
34-1615-00 DOOR RELEASE MECH, INSIDE, R/H 1 EA $32.85
33-0720-00 DOOR HANDLE, IN: RODS 2 EA $22.50
34-1575-00 ESCUTCHEON, IN. DOOR: RODS 4 EA $7.80
32-0176-00 TRUNK SEAL, ROUND #75001359 12 p/ft $45.00
06-1075-00 GAUGE, FUEL CHROME: ALL 1 EA $48.00
06-1070-00 GAUGE, OIL PRESS CHROME: ALL 1 EA $48.00
06-1089-00 FUEL SENDER, UNIVERSAL 1 EA $52.98
06-1091-00 TACHOMETER, CHROME: ALL 1 EA $128.01
06-1120-00 SPEEDOMETER, CHROME: FD/CV 1 EA $117.00
06-1095-00 GAUGE, WATER TEMP, CHROME 1 EA $48.00
06-1062-00 VOLTMETER, CHROME: ALL 1 EA $48.00
06-1073-00 SENDER, OIL PRESS: ALL 1 EA $53.25
06-1105-00 SENDER, WATER TEMP; FD/CV 1 EA $37.92
50-0030-00 SPORT STEERING WHEEL BLACK 1 EA $50.85
06-1178-00 STEERING WHEEL ADAPTOR CHEV 1 EA $44.79
26-0300-00 WIRING HARNESS, 20 CIRCUIT; ALL 1 EA $375.00
33-0460-00 LIGHT, LICENSE 1 EA $40.35
TOTAL 166 $1,979.47
DOOR & WINDOW GLASS
23-0096-00 WINSHIELD CLEAR: ’34 COUPE 1 Ea $90.00
23-0097-00 GLASS, DOOR, CLEAR, LH/RH: ’34 2 Ea $132.00
26-0456-00 WINDOW, REAR CLEAR: ’34 1 Ea $54.72
TOTAL 4 $276.72
BOX # 5
23-0010-00 GRILL INSERT: ALL 1 EA $484.05
TOTAL 1 $484.05
BOX # 6
22-0027-00 HEADLINER, _________________ 1 EA $141.39
TOTAL 1 $141.39
FIBERGLASS COMPONENTS
TOTAL 166 $1,979.47
DOOR & WINDOW GLASS
TOTAL 4 $276.72
BOX # 5
TOTAL 1 $484.05
BOX # 6
TOTAL 1 $141.39
ROD RETAIL PRICES
21-0008-99 MAIN BODY, PRIMER :’34 COUPE 1 EA $4,363.02
21-0021-99 HOOD, PRIMER: ’34 COUPE 1 EA $624.00
21-0031-99 RT ENG SIDE PANEL, PRIMER: ‘34 1 EA $243.93
21-0041-99 LT ENG SIDE PANEL, PRIMER: ‘34 1 EA $243.93
21-0049-99 DOOR W/LINER LT, PRIMER: ‘34 1 EA $541.92
21-0059-99 DOOR W/LINER, RT, PRIMER: ‘34 1 EA $541.92
21-0076-99 GRILLE SHELL, PRIMER : ’34 1 EA $211.74
21-0188-99 DECK LID W/LINER, PRIMER: ’34 1 EA $499.62
21-0135-99 DASHBOARD, PRIMER : ‘34 1 EA $211.74
21-0159-00 DIVIDER, SEAT & TRUNK: ’34 1 EA $353.91
21-0095-00 SPL APRON, RIGHT/FNR : ‘34 1 EA $81.30
21-0105-00 SPL APRON, LEFT/FNR: ’34 1 EA $81.30
21-0125-00 FLOOR PAN, : ALL RODS 1 EA $431.70
21-0163-00 TRIM PNL, REAR QRTR, LH: ’34 1 EA $77.07
21-0164-00 TRIM PNL, REAR QRTR, RH: ’34 1 EA $77.07
21-0136-00 PANEL UNDER DASH, PRIMER ’34 1 EA $220.20
21-0186-00 RH WHEEL WELL: ’34 COUPE 1 EA $186.36
21-0187-00 LH WHEEL WELL: ’34 COUPE 1 EA $186.36
21-0189-00 TRUNK LINER, ’34 COUPE 1 EA $330.18
21-0139-00 HEADLINER : ’34 COUPE 1 EA $347.10
22-0495-00 FIREBOARD FOR DOOR PANEL: ALL 2 EA $12.00
TOTAL FIBER GLASS 22 $9,866.37
INCLUDES
24-0013-00 ’34 COUPE, MAIN FRAME 1 EA $4,500.00
24-0310-01 RACK BOLTS GRADE 8, 5/8 X 3 3/8 2 EA $4.62
24-0315-00 LOCKNUTS/RACK BOLT GRADE 8 2 EA $1.14
24-0315-01 RACK WASHER 5/8 GRADE 8 4 EA $2.16
24-0067-01 DRIVE SHFT LOOP BRKT: REV. 2 EA $125.10
24-0805-00 BRKT, LOWER RAD MNT: RODS 2 EA $27.00
24-0760-00 PEDAL, BRAKE: ALL RODS 1 EA $48.00
24-0160-00 MOTOR MNT FORD, LH : ALL 1 EA $85.05
24-0165-00 MOTOR MNT FORD RH: ALL 1 EA $85.05
24-0099-00 TRANS.CROSSMEMBER: RODS 1 EA $99.00
24-0326-00 GAS TANK ALL RODS REV- 6/94 1 EA $810.00
24-0690-10 REAR FRAME BUMPER BRACKETS 2 EA $78.00
09-0046-00 MANUAL ’34 COUPE 1 EA $50.40
INNER DOOR METAL 2 EA $588.00
TOTAL METAL 23 $6,503.52
