kit car
thanks alot for all the info
Street beast builds
There are things IMO, that have to change to get the car to sit right, ffas23 and myself don't agree on this but I think the car sits to high in front, I have been around hot rods a long time and built a lot of them and unless you are trying to get a gasser look, the fenders always come down over the tire some. These are not easy car to build, But you can end up with a nice looking car if you take your time, and depending on what you want. Don't think you will get rich on it, The car market is very soft right now. Change a few things, re-do some things like the frame, IMO the frame is a little weak and the welds are not that great, to suit me. You can build it by the book or build it on your own, On mine I went on my own, changed a lot of things and built it how I wanted it to look. I started mine along time ago, pushed in the corner a lot, to work on other cars, but I will get it done this summer or fall. It's your choice as to buy it or not, and if you want to do what it takes to build it. If it were any other car where you had to buy all the parts, it is a very good deal. So if you have built other cars this one should be not that much different, as long as you know you might have to change some things. We will help you if you get it. Bob |
I think 6500 for every thing is a good price. hells bell the two motors and the tranny cost that . That said the 34 BEAST as most ever thing else will have its flaws and yes they do set a bit high as Bob said at lest for some's taste but as you have built more then one you provably know that a snip and weld back can fix a lot. Just remember if the book said to sand to fit they an't joking. Good luck if you decide to build it.
OLDROD |
street beast builds
Bob |
OLDROD |
street beast builds
Bob |
Street Beast builds
Greetings,
Well, I am new to this forum, but I am in the process of finishing up my 34 three window. It has been a long journey. First thing I did, was throw away the manual!! If you use all of the junk yard parts they tell you to get, you will end up with a junk yard car. These kits are not for the un-itiated. They are hard to assemble, and make things fit properly. I have gone through 2 gallons of epoxy resin, and around 20 yards of cloth. There were two things that were the hardest to do. Hang the doors so the body lines matched up, and install the headliner. I cut the head liner in half, welded in more support backing, and screwed in into place. I think each door took me in excess of a week each. The windows in the doors were done like a regular car door. Glass run channel, belt line rubber and fuzzy strip. If you install the windows like they suggest, all you will hear while driving is wind howl, as nothing is sealed. I would not use another one of these. But I have one, I am going to finish it, and I will never sell it off. The cost is pretty steep, but then what isn't these days. I got pretty lucky, and the body was pretty straight. They did lie to me about the rear end and tire sizes. Should have narrowed the rear end by 4 inches or so. I ended up getting custom made wheels, with a great deal of back space, So they fit the wheel wells properly. I had to re-weld a lot of the frame. the pockets for the upper control arms on the rear end, were in the wrong place. the frame is built so as to make it hard to get the exhaust out. Has to hang under the frame. When it is all said and done, this is a pretty hard car to build. I have looked at a lot of them. And the skill level of the builder was always apparent. some looked really nice, some did not. But they were all proud to have completed them. That is the main thing. Wayne |
Street Beast build
Got any pics of yours. we are here to help people that are building one and might need it, I'm sure you can help. It is not a thread to knock the car or put it down, there is another thread for that, and everything has just about been covered on that thread, as far as putting it down. like I said this is to help people because it is not that easy. These cars IMO can look good if you but the time in them. I'm just waiting to get into the body shop to get it painted on mine. I will post a couple pics for you. Oh nothing has been adjusted on my doors or hood, in these pictures yet, I did have it all set up once, but took it apart. Bob Last edited by 35terraplane; 03-18-2011 at 12:41 PM. Reason: add |
Street Beast builds
Hi,
I really like your grill shell. You must have built it yourself? Your body appears to be an older model? I can see some differences. Are you going to use the side cowls? A friend of mine is a fiberglass expert. He helped me out with a few things. Just small bits of advise, but it sure helped me, because I really hate working with fiberglass. Tried to keep things as clean as I could, but it seemed that I was always cutting or grinding something. I had always heard of guys talking about a "flat" dash. Never really knew what they were talking about, until I started to do the dash on this thing. It is not even close to being flat!! Should have cut it apart, and made it flat!! Not so much of a big deal if you are mounting individual gauges. But try it with a big flat insert. when I figure out how, I will start an album. I tried to take pictures as I went along. Thanks, Wayne |
Street Beast builds
Hi ffas23,
When I did the rear window, I was really unsure about how to get it mounted, keep it flat, and then line up the headliner exactly in the opening. so, I made a form to build the flat surface around the opening, then cut the hole for the window in the body. I then fit the back half of the headliner, and marked the opening. This helped me get it set to right height, and keep it centered. then I used an oak board with sand paper, and made the flange around the window dead flat. Then sanded the headline to match that surface. Seemed to take forever. I had a list from SB, itemizing all of the stuff needed from the junk yard. From suspension, brakes, rack, steering column, seats, rear end, emergency brake, wipers. the more I looked, the more I realized I did not want this stuff. so, I used after market stuff. I was really steered in the wrong direction on the folks I got my engine from. They recommended T&L Engines. Well, I ordered the engine from them. Big mistake. I did eventually get my engine from them. Had some problems with the rocker arms they used. Did not line up with the valves. Dart said not to run them as they were. T&L said to pull the engine, and send it back to them. They would not replace them. So I did, and they look good now. But T&L is out of business now, had to sell off all of their equipment, and his house to pay back all the folks he screwed over. Now he has some pretty severe limitations on how he can do business. I haven't ran the engine yet, might be little bit scared to!!LOL This is the first kit car I have done. Probably the last one. Just thought it would be fun to do while retired. Kind of have the itch to build a drag car!! Haven't had enough pain yet!!! Wayne |
| Recent Hotrodders' Lounge posts with photos |
| street beast | Kirk Gregory | Introduce Yourself | 3 | 09-04-2008 06:49 PM |
| street beast | Kirk Gregory | Introduce Yourself | 1 | 10-05-2007 10:42 PM |
| My 33 Vicky Street Beast | Fred Martin | Introduce Yourself | 4 | 12-06-2006 02:49 PM |
| Street Beast 41 Willys | bobthetran | Hotrodders' Lounge | 17 | 05-04-2006 11:14 AM |
| Street Beast Company | Dave E Shank | Hotrodders' Lounge | 6 | 10-02-2003 10:02 AM |
