Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Street Beasts '34 build starts
  #24 (permalink)
Old 08-13-2008, 06:09 AM
kwhizz kwhizz is offline
Last journal entry: 1937 Ford Club Coupe LS2 build thread
One of the frustrations that I endured was that one of the four hubs (the front hub passenger side) didn't have all of it's bolts mounted to a perfect 90 degrees. This caused a problem as the wheel and tire couldn't mount the hub due to the bolts being out of alignment. The solution was to ground out the aluminum wheel with a dremel and then mount the wheel tight so as to properly reset the bolts and mount the tire.
Jay..............You're "Kidding"...........Right...............It will be Interesting to see if you are still such a supporter of Street Beasts after you get a Better understanding of what you got yourself involved in........Right now you are a "Babe" in the Woods........
