Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Street Beasts '34 build starts
  #28 (permalink)
Old 08-13-2008, 04:46 PM
matt167 matt167 is online now
Wiki Edits: 31
build a frame of sorts for your body while it is in storage... Fiberglass does not fully cure right away and eventully takes a 'set' in whatever position it lays in. just square up the body, throw together some 1X1 square tubing to hold it that way ( just thru bolt the stuff togther ), and you will be good..
