Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Street Beasts '34 build starts
  #74 (permalink)
Old 12-02-2008, 10:11 PM
NEW INTERIORS's Avatar
NEW INTERIORS NEW INTERIORS is offline
Set no limit's on yourself
Originally Posted by ret_marine2003
You are absolutely right to say Glass never rusts, but the structure that it is attached to often rots and glass crazes and cracks with temperature variations, weather, and time.
Just pulling your Cain a little... Well first off .. todays frame's are built a lot better and last a lot longer.When a glass kit is set up right,You can get away from the cracking problem's.I had a glass car I built,And used it a lot,And took it on some long trips too.Never had any of the problem's you mentioned.But I did see some rods with them problem's. And it does get real hot down here in the South.....
