Street Beasts '34 build starts - Page 19 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #271 (permalink)
Old 02-16-2013, 10:30 AM
35terraplane's Avatar
Originally Posted by JGK95 View Post
Hi Bob,
Yes that is aluminum embedded beneath the surface as every owner of a SB experiences that problem due to the design of our cars. Heck, before our car was modified to its present appearance, those four corners of the trunk and each window slot's opening had already begun cracking. The decision to use aluminum was to prevent future cracking & the need for repairing/repainting the car annually.
Having shared what I experienced first hand, of course I'd appreciate anything you could share.
Thank you Bob!
Jay K.
Ps. When're you going to post updated pictures of yours in the other SB thread?
Jay I know the corners need fixing but it won't last if you put alum between fiberglass the metal works it's way loose, there is a type of epoxy that you should use,what you have done looks good for now , but it won't last, if it were me I would redo the whole works.
. but that's me.
If you want to know what it it is let me know.
Bob
  #272 (permalink)
Old 02-16-2013, 02:54 PM
JGK95's Avatar
Last journal entry: Test Entry
Hi Bob,
Yes please. Let me know the name of that epoxy.
Jay K.
  #273 (permalink)
Old 02-16-2013, 06:17 PM
Hi Bob,
Jay K.
Jay I will have my wife get it and I will get it to you. I would think you can get it at anyplace that fixes lots of vettes.
AS far as mine, I'm afraid I'm done working on car, my hands are too screwed up, can'feel anything. I will have to have someone else finish it. Not what I wanted, but that's the way it goes. will be there to guide who ever along so that it comes out the way I want it.
I will try to take pictures, but I am not big on it.
BOB
  #274 (permalink)
Old 02-17-2013, 04:08 PM
JGK95's Avatar
Bob,
Thanks for taking time out of your afternoon to talk with me today. I greatly appreciated it.
Jay K.
  #275 (permalink)
Old 02-19-2013, 05:29 PM
Bob,
Jay K.
Jay IT wa my pleasure,I love helping younger Rodders, when they are building either glass or steel cars from the 30's I will jump to help.
Like I said don't cut corners and Don't get cheap at the end. If you go over budget go, but don't take it out on the car.
Give me a call anytime be glad to talk.
Bob
The Following User Says Thank You to 35terraplane For This Useful Post:
JGK95 (02-19-2013)
  #276 (permalink)
Old 02-20-2013, 04:31 PM
vacuum brake booster
i'm progressing slowly with my 34 SB cabriolet build. working on getting all the frame welding done before strip down, paint and rebuild prior to getting started on the body. i have an LS1/4L60E engine tranny. the engine position does not allow for a standard vacuum brake booster/master cylinder combo.
was looking at hydro boost but that is too long, i don't like the look. i found an import vacuum booster that's 3 1/2" deep that could work. my question is are the booster studs a standard? How do i find the specs on this booster to determine if it will provide enough assist? here is a link to my build progress on facebook.
https://www.facebook.com/home.php#!/...7327883&type=3
thanks all for your input
ray
  #277 (permalink)
Old 02-22-2013, 11:04 AM
Ray I tried going to your link but it wouldn't open, as far as your other question I don't have an answer for you sorry.
BOB
  #278 (permalink)
Old 03-20-2013, 08:19 PM
For the First Time....THE BEAST RISES!
Apologies as you'll have to both click on the link and then turn your head sideways!
Very nice thanks for the videos!
  #279 (permalink)
Old 07-17-2013, 09:07 PM
JGK95's Avatar
Just in case you all thought I was sleepin' on you all.
See below.
The Beast can see you now!
Jay K.
  #280 (permalink)
Old 07-17-2013, 09:34 PM
life is a temporary assignment
  #281 (permalink)
Old 07-28-2013, 04:39 PM
JGK95's Avatar
More developments
  #282 (permalink)
Old 07-28-2013, 04:48 PM
JGK95's Avatar
Before:
After:
The headlamps once received from AutoLoc did not allow for much realignment, thus we had to build up the fender underneath the headlamp housing to accommodate for the headlamp setback. Pretty D@mn impressive fixing the flaw in broad daylight, huh?
No more Cross eyed Mary!
  #283 (permalink)
Old 07-28-2013, 08:08 PM
Looking very nice Jay...
  #284 (permalink)
Old 07-28-2013, 08:36 PM
Looks very nice, keep up the good work.
Bob
  #285 (permalink)
Old 08-12-2013, 10:11 AM
JGK95's Avatar
I forgot to mention that we also cleaned up the fender radiuses (radii) as a friend on here pointed out that the molds in FL were poorly executed around each fender opening.
Cheers,
Jay K.
Street Beasts ShannonSteele Hotrodders' Lounge 19 11-26-2012 07:48 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
34 ford frame build Crazy Canuck General Rodding Tech 5 10-01-2004 02:10 PM
Any Street Beast 34 Coupe builders? Pilot34Coupe General Rodding Tech 7 05-14-2004 09:41 PM
Street Rod ( Autobody ) Schools Dusty Hotrodders' Lounge 0 01-05-2002 08:25 PM
