Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - street big block compression
Old 11-15-2008, 02:01 PM
Packard V8 Packard V8 is offline
If the cam duration is long enough to bleed off some compression at low RPMs. Naturally, that much cam duration loses low speed power and fuel economy.
A better real world measure is cold cranking compression. If everything is right, you can run 200PSI on 91 octane, IF you have aluminum heads and IF the carb and distributor tune are spot on and IF you have a low rear gear.
thnx, jack vines
