Street Engine w/ Boat Cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2009, 07:53 AM
BG383's Avatar
BG
I've come down to a cam that i believe is suitable for my Set Up, however, its a "boat cam" (comp camXM278H). It's going in a 383 with 10.6 compression, 3:73 gears, 3000 stall, AFR/Broadix 195 heads, airgap intake,750 carb,1.52 rockers, 87 monte carlo, Will see street most of the time (some strip) so I wanted a cam where low-end torque is Present.... A cam with a nice racey (rough) idle. Looking for 500/500 HP/TQ....Does anyone oppose this set up; Are there dyno numbers on this cam(can someone run a dyno sim); And any other cam sugestions?
Old 08-05-2009, 09:52 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
I believe you'll find that the reason this is a "Boat" cam, is because it is designed to run at WOT. I would bet that on the Street, for everyday use, it will run lousey...FWIW...
Old 08-05-2009, 01:24 PM
OLNOLAN's Avatar
It'a Sweet Camshaft
Hey bud, I thought the number sounded familiar. This is the same cam I have in my boat engine. It is plenty streetable in a car engine. Has a nice lope, will idle down to 500-600rpm,tachs up real quick. The only difference between it a the same car grind is the 112degree LSA vs 110 LSA. Helps w/low end and idle quality. But,not wanting to bust your bubble,It' not gonna make 500hp. Maybe 400+. If you want a recipe for a 500hp/500tq 383,see the March 2005 Hot rod magazine article "The 500/500". Hope this helps.olnolan
Old 08-05-2009, 07:50 PM
motorhead454's Avatar
AFR/Brodix? either or? you have the compression just dont think that cam will get you to 500/500. swap those afr's for some 227's and a good single plane with a 950cfm and you should be right about there. Make sure you go mechanical roller!
Old 08-05-2009, 09:52 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Low end torque and racey idle don't mix.
Most boat cams are designed for broad, flat torque curves, modest RPM peaks, and avoiding exhaust water reversion. Usually the only boat cams that really work well on the street are the milder boat cams, and they work best on very mild street builds.
I have a boat cam (mellling 22024, 203/212 on a 112 LSA) in a pickup. It makes great torque and mileage, but wusses out at 4800.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Hydraulic Flat or Roller??? Chevy 383 Street engine? 89SDime Engine 38 02-23-2011 12:00 AM
new cam engine wont fire elcaminodragster Engine 30 12-09-2007 01:59 PM
is this a good street engine? Mike_82 Engine 5 03-19-2004 09:31 PM
New Engine build, is cam gear one tooth off? fordSR Engine 16 12-15-2003 05:05 PM
