Street Rod electrical problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2004, 09:07 PM
My '34 Chevy street rod has multiple wiring problems. When you turn the key, frequently it does nothing. It doesn't matter if it's hot or cold (more frequent when hot). Had three electricians make repairs but the problem comes back. Need help from an experienced electrician in the Dallas area. It's a painless wiring system with a GM column.
Old 11-18-2004, 01:51 AM
docvette's Avatar
Wiki Edits: 12
Re: Street Rod electrical problems
Doc here:
you get No "Click", no lights, radio and the like?
Loose or bad fuse link or wire going from the solenoid, or loose battery cable/link wire at the solenoid...would be the first place to look...
More on what it dosn't do would be helpful...
Doc:
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 11-18-2004, 07:35 AM
302 Z28's Avatar
Above advise, plus if it's a glass car check all the grounds.
Vince
Old 11-18-2004, 08:19 AM
Doc and Doug, thanks for the advice, that's definitely something I can tackle on my own and see what happens, I'll go through the grounds and cables to the starter/solenoid.
As for more "info" I was just told the wiring to my column is a mess and there's some hot wires that need to be repaired, but they couldn't properly trace the prob.
I was told the car has everything running to the alt (not directly to the battery) so you don't get anything when you turn the key, not even a click. When it is running, power doesn't work until you rev it over 2,500 rpm and the alt "kicks in". The last guy re-routed the headlights on it's own line w/fuse, but that didn't fix the problem.
Old 11-18-2004, 08:38 AM
docvette's Avatar
Wiki Edits: 12
Wiring
Doc here
Is the alternator 1 wire or 3 wire?
If its a 3 wire wire the car as per the attached photo and your problems should all go away....
(start wire not shown in photo, run it from start side of key switch to the "S" on the solenoid)
If it s a 1 wire run battery power and ground main cables to the starter, positive to the big solenoid terminal, ground to the nearest bolt to the starter.
On the Same main starter terminal attach your fusible link (That supplies power to the rest of the car) and the alternator wire.
On the "S" terminal , Attach your Wire from the start side of the Key switch.
On the "I" terminal run that wire to the ignition coil power wire (secondary Ignition)
Thats pretty much it..It should start, run and charge no problem!
Check all your grounds, and run extra ones if you think you may need one.
Doc
Name:	67-8 ignition.jpg
Innovations
Old 11-18-2004, 04:07 PM
302 Z28's Avatar
Sounds like you need to purchase a quality wire kit and start from scratch. It's really not that big a deal with todays wiring kits.
Vince
